Results 1 to 7 of 7
    Nov 2018
    Claremore, Ok.
    Default Where can I find ECU codes? Just got P0173
    Where can I find the ecu codes. Just got code P0173.
    Last edited by Peter Aawen; 10-10-2023 at 10:56 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Jan 2021
    Descanso, CA
    Lightbulb
    I suggest you start with your vendors
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Member KHB1's Avatar
    Oct 2023
    North Coast of Germany
    Hi, google says fuel injection cyl 2....
    2023 S2S Shadow Green
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Weird! All 3 docs I have with codes and NONE of them show 0173.... Not even the MAIN Spyder Master Repair Manual!!
    But online here, they do!!
    https://powersportsguide.com/can-am-fault-code-list/
    Chuck
    Jun 2016
    Harrington, Australia
    P0173 on SpyderCodes -
    ‘From the generic database:
    P0173 Fuel Trim Malfunction (Bank 2)”
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jan 2021
    Descanso, CA
    Concur with the standard diagnostic cause but Rev is running a fairly complex applique of A/F-related hardware, firmware and connectors. Therefore I doubt the standard isolation and resolution will obtain. After reading the various materials at the DynoJet site, I think the two most likely causes are a corrupted A/F map or connector/wiring damage. And of course there's always our favorite perennial, a tired battery with loose connections.
    Aug 2019
    Stoughton, WI
    Have you tried reflashing with your .stk map?
    2022 RT Sea To Sky
