Results 1 to 16 of 16
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Default Has anyone come up with a Device to hold RT lid open?
    Has anyone come up with a device that secures the lid on the back case of an RT in the open or up position. My wife gets her head banged every time she opens the lid to find something.
    Last edited by Peter Aawen; 10-05-2023 at 02:55 PM. Reason: Expanded title to briefly ask the question... ;-)
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Oct 2016
    Faribault, MN
    Yes Pierre at CanAMSpyderAccessories.com has a 3D printed lid holder, some folks just buy the extra strut and fittings that then hold the lid up (if you've added a luggage rack on the lid).
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2017
    Picacho, AZ
    Lamonster sells a heavy-duty strut. I bought one when I got the luggage rack. So far it works great.
    Oct 2021
    Shenandoah Valley, Va.
    Pierre from Can-AmSpyderAccesories.com had one that works great for 2019 and older spyders with a top case.
    Oct 2021
    Wichita, KS
    Quote Originally Posted by DGoebel View Post
    The printed piece will not work on the 2020+ models (which I see you have). Buy the LaMonster strut. Like Old Willie I installed one a month ago. It will do the trick for sure. Install takes about 10 minutes. Easy Peazy!
    Peter Pan has struck again!
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    I printed my own before I found out it was sold online by Pierre.
    Here is how it works !
    Brgds Martin
    First Spyder: RS 2008 Yellow&Black - Current: 2012 Spyder RTS Magnesium, bought new from dealer in 2015.
    Apr 2022
    Southern Norway
    Ooops, did not see that yours is a newer model. My bad.
    Brgds Martin
    Feb 2020
    illinois
    Quick easy fix is a rubber small door stopper between front of lid and rear seat.
    Active Member slhanks004's Avatar
    Nov 2022
    Gilbert, AZ
    Show Chrome makes a beefier strut for the trunk lid on 2020+ RT models. I ordered mine from Slingmods, about $35.
    Scott (slhanks004)
    Gilbert, AZ USA
    2022 Spyder RT Limited - Carbon Black
    • Pedal commander
    • Baja Ron sway bar
    • TricLED tail lights
    • TricLED driving lights
    • Corbin seat
    • BRP rider backrest
    • Lamonster topcuff (2) w/ RAM mounts
    • 12v/USB docking station
    • Garmin Zumo XT
    • RLS cat delete pipe
    • IPS highway pegs
    • IPS belt tensioner
    2022 RT-L , Carbon black
    Apr 2023
    FL
    At the Motorcycle Safety class they told me to always use my head. So I do. Were I shorter it would be a problem.
    Chip
    2020 RTL
    "Stella by Starlight"
    UltraGard Full Cover, Front & Rear Cup Holders, Elka Stage 2 Rear Shock, TC & Dave Signal Button, Spyder Extras Sway Bar
    Feb 2011
    Loganville, ga
    Thanks… Before I could order something she cut a small piece of wood to place under the hinge.Cheapest of all the solutions.
    Jun 2016
    indpls in
    until you forget it and break the hinge
    Danbury Connecticut
    Quote Originally Posted by Pennyrick View Post
    You may find this helpful. It worked for me.
    https://www.spyderlovers.com/forums/...=1#post1645384
    IBA #47122
    2020 RT Limited Asphalt Grey
    Aug 2019
    Stoughton, WI
    Will the Show Chrome strut support the lid with a luggage rack installed?
    2022 RT Sea To Sky
    Jun 2016
    indpls in
    yes it will
    Active Member GreyGhost's Avatar
    Sep 2021
    North Texas
    Yes, it works with a luggage rack..
    2021 RTL Chalk White (a paler shade of grey, of which there are 50)
