Results 1 to 12 of 12
    Feb 2019
    Uss
    Default Any advice on side luggage compartments that won't open?
    Ty - 2020 RTL, I'm kind of stumped?
    Quote Originally Posted by Mikey4201 View Post
    Have you tried pushing in the door while pulling the release lever??? .... Is the compartment over-filled??? ... Mike ...PS if the latches are really dirty spray with carb cleaner and then dry silicone .....
    Last edited by BLUEKNIGHT911; 09-15-2023 at 09:02 AM. Reason: Fixed quote display ;-)
    Sep 2017
    Durham,Maine
    Sometimes I have to pop mine with my knee and pull the lever at the same time if I have it stuffed. And also, some people are having to make adjustments to their cables because the factory didn't do a good job, so you have to take some of the slack out. When you get the door open, you look up there and see where the cable runs into the lock, you'll see an adjuster with two nuts, loosen the jam nut and make your adjustment! Good luck
    2012 RTL , Pearl
    Oct 2016
    Hamburg pa
    i took mine to the dealer , they had to adjust and lube the cable
    May 2013
    Apex, N.C.
    All of the above are correct. I actually broke the handle on mine trying to open it. And I am definitely not the only one. But sometimes they will be a little too full and you have to push against them with the knee and pull the handle at the same time. Really poor design on the 2020+ RT models.
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    My 2020RT side case lids were almost impossible to open, even banging on the lid as has been suggested. I found TSB # 138444 that tells dealers to replace the cables controlling opening of the lids.
    I had mine replaced a week ago, and the lids open just like new now. (original warranty applies, so it may have expired).
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    There is a service bulletin for this on some years. Look on NTHSA.gov website.
    It replaces regular cables with stainless cored ones.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
    Danbury Connecticut
    Quote Originally Posted by mecsw500 View Post
    Mikey4201:
    Yes. mecsw500 is 500% correct. Here is the specific TSB. Contact your dealer with this information and they will replace your cables at no cost to you.
    I had mine replaced after breaking a latch.
    Now the bags open with almost no pressure on the latch.
    As always, my free advice comes with a double your money back guarantee.
    IBA #47122
    2020 RT Limited Asphalt Grey
    May 2013
    Apex, N.C.
    Quote Originally Posted by ThreeWheels View Post
    Mikey4201:
    This is good news. I wish I had it 3-4 weeks ago when I got mine replaced. I had it done at the dealership, but they said there was not a TSB. It was no big deal, because I had the extended warranty. But I had to pay the $50 co pay. But the way I see it, that could have been $50 worth of gas.
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Adjust them.
    It was really easy on my '18 RTL. Pushing the side while pulling up on the lever to open it got old REALLY quick.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Jun 2011
    Near Lexington, NC
    On '20-up, lay down on floor, look up under towards front of bag and you will see the cable adjuster. Loosen tiny lock nut, screw adjusting nut one way or another until your lid opens when you pull the latch.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Oct 2021
    Wichita, KS
    Your cables are probably corroded. That's the reason for the TSB. No amount of adjusting is going to make it better if they are corroded.
    Peter Pan has struck again!
