There also appears to be a fitment issue between the mud flap and upper fender by looking at the gap, and between the right and left sides. Cause or effect? Hard to tell by the photo.
250 miles from home and a buddy notices my mud flap rubbing and melting. 300 miles on it. Likely going to cut it off and let dealer replace. ��
Who changed your rear tire? Is that the original Kenda, looks to be a General, who ever changed that tire should have seen the potential problem! My 2 cents. Bill
2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
BaJa Ron Ultra 3 pcs sway bar kit
7jurock 25" tinted windscreen w/flip
Frogman Dave's "Signal Button" If in Doubt, Don't Do It!
" Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
We had exactly the same problem after an air bag collapse. Usual symptom is an extremely harsh ride where you can feel every little bump. Think old-time Harley before they grew springs.
Chip
2020 RTL
"Stella by Starlight"
UltraGard Full Cover, Front & Rear Cup Holders, Elka Stage 2 Rear Shock, TC & Dave Signal Button, Spyder Extras Sway Bar
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Funny this should come up. I went on a charity ride for Pediatic Brain Tumors yesterday and noticed my rear flap on my 2021 RTL looking the same. Not sure how it came down. I am thinking about checking to see how much room is behind the flap and the tire. I might use a plastic screw and nut to go through the middle to hold it in place. If I can do it from the inside and then trim the end, it should give me better clearance and piece of mind.
