Dealer set 2022 RTL tire pressures waay high - what do you use?
I just took my 2022 RT in for service and they aired the tires to 30 on the rear and 25 on the front. I thought 25 was too much.
I thought it was supposed to be 18 PSI
What pressures do you guys use?
Reason: Expanded title to briefly ask the question... ;-)
17/18 cold all the way around.
Since we are all so individually different in size, weight, skill and riding temperament, the best thing to do is start at the pressures listed on the label under the seat and adjust them the way it feels best for you. FWIW, when I took my Spyder to the nearest dealership for a NC state inspection last year, the inspector, after the job was done, attempted to tell me what I was doing was all wrong and that he had done me a favor by putting them all at 28 -- and I have three cage tires on it to boot. I went around the side of the building out of sight of the service dept, pulled out my tire gauge and put them back where I find them best for me. BS hides in every nook and cranny in the universe, and it's a fact, BS at the speed of light is still BS!
I sometime marvel at how little some dealer techs know about the Spyder, Ah-cool. Firstly, are we referring to the OEM Kendas? If yes, the front pressure should be around 17, according to the workshop manual. Why they have not followed BRP specs is beyond me.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
I assume that’s on aftermarkets, 2dogs?
HeliBars Handlebars
Kenda Kanine rear.
and THIS post is why posters should ALWAYS give us ALL OF THE PERTINENT INFORMATION with the question. ie... original tires or aftermarket tires? Big difference between the two.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
I go by the OM and/or sticker +/- 1 adjust psi as needed. Hasn't failed me yet.
Woh, I thought veh. inspections in Vt. were tough! .... So you're saying yhat in NC they check the "tire psi's"? ..... OMG ..... Mike
Reason: Caps & ' 's ;-)
Just an update original tires. I only have 6,000 miles on it so far. 2022 RTL
No, Mike, the NC inspection does not check tire pressure, only tread wear. Matter of fact, every year but two since I bought the Spyder, having it inspected at cage shops I've just driven it into the inspection bay, sat aboard it flicked the appropriate switches in response to the inspector's signals, and driven out with my new inspection certificate. At one motorcycle dealership that shall remain unnamed the inspector told me I had to replace my license plate light. All lights must work or the vehicle flunks.
Yes, it is. They'll get up to 20 +or- when hot. Works well with one or two up. We're approx 300 lbs two up. Plus you'll never get that rear tire to run out evenly. It will always wear out the center first.
Yes, he checked them somewhere in his sequence because he told me they were too low and set them at 28 all around. When I left my house they were 18 front and 20 rear. It's 15 mi. to the dealership at probably and avg of 40 mph.
20 rear? I thought rear was 30
The sticker on my Spyder says 28 +/- 2 for the rear, but I have been using the General Altimax RT43 for years and run it at 20 for even wear across the entire tread. Kenda tires are crap.
My dealer set my OEM/new Kenda's to 15# front and 20# rear. They looked a little low when I got home from my 90 mile ride from the dealership
2022 RT Sea To Sky
@troop....so they did not follow the sticker pressures either? Just goes to show poor BRP dealer quality and training ...
2024 RT Sea to Sky (back at dealer again due to blank screen issues, loss of BT and WIFI :-( :-( AND the new cluster BRP sent is not linking to the bike properly = BRP fail again)
Honestly from the few that I've saw, there was no training and I think that they were hired cheap. Welcome to small town USA.
Ahh-cool, you really do have to be sooooooo careful when discussing tyre pressures. ALWAYS ask the question - are you running aftermarket tyres?. In my opinion, it is as essential to include that tyre info in your signature as it is to include your model year…… but we can’t even get people to include their model in their signature. It is sooo frustrating
HeliBars Handlebars
Kenda Kanine rear.
They quit doing inspections or emissions for bikes or trikes in Utah. Just pay up for a sticker.
In some ways that's way more convenient, but in others it scares the living daylights out of me.
Can Am Syder RT Limited (2021)
Triumph Bonneville T120 (2018)
Hardly anyone on this site has ever checked their tire pressures using the chalk mark method on their tire treads. Amazing how such a simple test gets no attention at all. JMO
Ozzie Ozzie Ozzie
