Results 1 to 22 of 22
    Jul 2023
    UK
    Default 2024 Spyder handlebar controls - Headlight switch is missing?!
    Hi
    Great forum - this is my first post!
    Has anyone noticed that the headlight switch is missing from the left controls on the 2024 models, and I couldn't see it on the right controls either?
    Last edited by Peter Aawen; 08-31-2023 at 05:32 PM. Reason: Expanded title to briefly ask the question... ;-)
    Vermont
    Quote Originally Posted by F430 View Post
    Hi
    F430,
    https://can-am.brp.com/on-road/us/en...itid=000H7RA00
    The above link shows where the headlight switch is on a 2024 F3 LTD Special Series. it is on the left hand side on the left handlebar, on top.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jul 2023
    UK
    Deanna,
    I don't see it there. There are controls for volume up/down and track forward/back, but I can't see the headlight dip/main?
    Active Member LongIsland's Avatar
    Dec 2018
    Long Island
    look in your owners manual, it should be listed in the table of contents.
    Current: 2022 RTL SE6 Red Marsala and 2012 622 Trailer Lava Bronze,
    Previous: 2014 RTL SE6 Black Currant - 58,746 miles,
    2012 RTL SE5 Lava Bronze - 19,675 miles
    Vermont
    Deanna,
    OK. What does the Headlight dip/main?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Jun 2016
    Harrington, Australia
    Deanna
    I’d say he is referring to the 3 way HighBeam/flash/Lowbeam switch, Deanna.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2017
    Wa.
    I just guessing. But I think it might be the button on backside of the left control. Used to be called push to talk maybe. In one video There was writing at that switch. Maybe high. push to flash., low. Just guessing. NEver seen writing on the back beside that button. There isnt a manual out on brp site for the 24's latest one on the page in for 23's. And the little control pad on the tank is gone now too. at least on the F3. I could be wrong on all this except on the control pad on tank.
    Idaho
    Deanna
    In other countries such as Great Britain, dip means low beam. Main would be high beam.
    2014 Copper RTS
    Nov 2018
    Waynesboro, PA
    What it looks like to me, the switch is on the left side in the back top. See photo of 2024 s2s below. it's hard to see.
    Link to F3 that shows it also if you scroll down https://can-am.brp.com/on-road/us/en...spyder-f3.html
    My Spyder
    2012 RTL , Brown
    Jul 2023
    UK
    Quote Originally Posted by CopperSpyder View Post
    Well spotted. This looks like a better place than the current one.
    Active Member Chief-J's Avatar
    Apr 2011
    Fort Belvoir, VA
    Check out this link, you should be able to see all switches and buttons.
    https://www.youtube.com/watch?v=Upep5y0TLeU
    Jun 2016
    Quote Originally Posted by Chief-J View Post
    Chief, did you actually watch this video before offering it as a solution to the headlight switch question? I just watched it again because I figured I must have missed the headlight switch in my first viewing. It is NOT in this video and I have just wasted 10 minutes of my life. I have posted this to hopefully prevent others from also wasting their time. Not happy
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Apr 2019
    Clinton, MS
    Here is a pic of the left side. I don't see it. And of course the only operator manual for 2024 is for the Ryker.
    2019 RTL Phoenix Orange
    Nov 2018
    Waynesboro, PA
    If I can get it to load here is a pic. I don't see it.
    That little switch sticking out from the back is it.
    My Spyder
    2012 RTL , Brown
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Agreed. The lever type switch on the front of the module is the normal place for the highbeam/flash switch.
    2020 RTL SE6
    Aug 2013
    SF Bay Area
    Looks like the headlight button is this one. (Shown in images below). The earlier models used a similar button for CB PTT then it became the BRP Connect dash switch button and now I think it’s the headlight as the dash control buttons are all on the front of the cluster.
    2021 F3 Ltd , Magna Red
    Jul 2023
    UK
    Shame they didn't backlight the indicators. Easy to hit the horn button at night.
    Apr 2019
    Clinton, MS
    After just a few uses to develop some muscle memory this location my work out great. You will no longer have to be careful of bumping the wrong thing. I think I like it.
    Feb 2024
    South FL
    Pete
    The headlight switch is on the top of the left control almost on the back of the control. I just picked up the 2024 and it is there.
    Vermont
    IdahoMtynSpyder,
    OK. Thanks for the info.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Pete
    Peteoz,
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Deanna,
    F430,
    OK.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
Tags for this Thread
