Results 1 to 14 of 14
    Active Member Smokes's Avatar
    Jan 2017
    Melbourne, Australia
    Default Just replaced my Original Yuasa Battery with another after 7 years!
    I just replaced my original Yuasa battery with another Yuasa after 7 years with no leakage at all. I'm happy to use the same type of battery, 7 years is OK in my book. I looked into Lithium batteries and couldn't see the point of paying more to save a few pounds. As long as the battery turns the crankshaft over OK and doesn't leak, I'm happy.
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Now, wash your hands
    Quote Originally Posted by Smokes View Post
    This should be a lesson to all who re-place their battery because they think they only last 3-4 yrs. ..... Battery maintenance is important ...... Thanks .... mike
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    Even though I get about the same life out of all my batteries, my plan is to replace the battery every 3 years. The Spyder is very picky about voltage and I prefer not to take a chance while out enjoying a cruise. I can continue to use the older battery in something else - so no loss. I too, am very picky about battery maintenance.
    Joe
    2023 F3
    Mar 2013
    Marion, Arkansas
    I replaced my battery in my 2017 F3 Limited earlier this year. I wasn't having any problems but just thought that 6 or 7 years was a good run for a battery. I did replace it with a Yuasa.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    You did good. The battery I replaced this year was due to my error. I did not leave it on the charger during the winter. It discharged all the way and was not recoverable.
    Jun 2019
    Deltona FL
    I got 5 out of mine while trickle charging it all winter in NY. Don't have to worry about that anymore!! Lol...
    Quote Originally Posted by Ex-Rocket View Post
    You did well with that Battery ..... Knowing WHEN a Battery is going to fail is problematic at best .... I'm no tree hugger, however disposal of batteries can cause problems in other ways ... I have said in the past, get a small Lithium battery jumper device ( $35 to $50+ ) If your spyder battery can't or won't start your Spyder use the jumper, and decide about the Battery in the comfort of your house ..... JMHJO .... good luck .... Mike
    Feb 2022
    New Zealand
    If you wish you can fit an inexpensive voltmeter and with that you can monitor the charging system rates. If something begins to fail you get a heads up all is not well.
    I have 1 on all my vehicles.
    Feb 2012
    Spring City,Utah
    I put one on mine. It consistently reads 13.7, but it reads .5 volts low so it really is 14.2 volts.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by Isopedella View Post
    Isopedella, where did you get that voltmeter and is it moisture proof?
    Feb 2022
    New Zealand
    Said to be waterproof. So far so good.
    From memory I got 1/2 a dozen or so from the E bay or AliExpress a few years ago.
    Cost was similar to a couple of cups decent cup of coffee or so. Nobrainer I reckon.
    I use some sticky back Velcro to mount em .
    Feb 2022
    New Zealand
    Another on my DR650.
    $10 Kiwi on E-bay....$3 to $5 on AliExpress.
    Pick your preferred colour.
    Active Member Latrappe's Avatar
    Nov 2022
    Flaxton Queensland Australia
    I am so glad it does not get that cold here in OZ we can Ryde here all year, so no real need for a battery tender just portable battery pack for those moments.
    2019 Can Am Spyder F3S
    ICSI Ride Hand Brake Kit as my right leg and foot does not work that well due to MS
    The Ultimate F3 Floorboard
    Baja Ron Sway Bar
    Shad Saddle Bags
    Lamonster F3 PACKRACK
    SHAD 58X in Carbon finish - Expandable TOP Case
    Pedal Box
    IPS Belt Tensioner and Handlebar Riser from Lamonster
    K&N air filter
    INNOVV K5
    Wilbers Nite Line Shocks
    RLS Cat Delete
    Floating Rotors with EBC Brakes for the front
    I am now broke
    I Should mention the Boss has a 900 Ryker Ralli next to my bike
    2018 F3S , Monolith Black
    Quote Originally Posted by Latrappe View Post
    A battery tender isn't for just cold weather. It's to keep a battery fully charged whenever it sits unused for an extended time period. Also, hot weather will kill a battery quicker than does cold weather.
