Results 1 to 4 of 4
    Aug 2020
    Ct
    Default Spyder 2020 RTL side compartment latches not working - common? Fixes?
    I'm having issues with the latches on the side compartments. I have to pull the latch hard while pushing in on the compartment to open them. Is this a common problem and is there a fix for it?
    Last edited by Peter Aawen; 08-21-2023 at 03:34 AM. Reason: Expanded title to briefly ask the question/s... ;-)
    Dec 2020
    Hartwell, Ga
    There is a tsb out on this. Take it to your dealer to fix. It would be best to take a copy of the tsb with you when you go.
    Another option is to try to adjust the cables yourself and maybe lube them.
    Click on this for the TSB
    Attached Files Attached Files
    Aug 2020
    Ct
    Thank you for this information.
    Jan 2022
    North Dakota
    I broke the latch handle off of one of mine. When I took it apart, I found the plastic mechanism to be defective. Put a new cable on it at the same time. Works like butter now.
    2021 RTL
    2021 RTL , Asphalt Gray
