Results 1 to 3 of 3
    Jul 2023
    OK
    Default Can anyone explain the ACS Rear Suspension Adjustments?
    I just bought a used 2014 RT and have read through the manual. I am confused as to what the schrader manual adjustment does vs the ACS automatic compressor adjustment for the rear suspension. Can someone explain please?
    Tks
    Dave
    Last edited by Peter Aawen; 08-19-2023 at 04:53 PM. Reason: Expanded title to briefly ask the question... ;-)
    Mar 2008
    Hesston, PA
    If the hard/soft dash switch does not operate the air system, the schrader valve can be used to inflate the air bag...(sometimes) Also can be used to check the air pressure in the bag... larryd
    Jan 2021
    Descanso, CA
    The air suspension system is used across a wide range of Spyder models, some of which have automatic fill-release capabilities and some are manual-only. BRP didn't bother removing the manual-only capability for the automatic fill-release.
