Results 1 to 4 of 4
    Mar 2021
    Ontario
    Default RTL Initial oil change analysis results
    First oil/filter change on the RTL a few days ago at approx 5000 Km/3000 miles. All looks good except for some fuel dilution, which I don't like to see. I did take it for about a 15 min run before doing the oil change.
    Attached Files Attached Files
    2022 Spyder RTL- dark trim
    1969 Plymouth Barracuda 340-S Fastback
    1969 Barracuda, 6.1 Hemi restomod, convertible
    1970 Plymouth Superbird, 440-6bbl
    Jul 2014
    Mint Hill, NC
    If you read pg 115 of your operator's guide it tells you how long a ride you should take to get the engine to proper operating temperature. Fifteen minutes isn't going to do it, and the coolant temperature gauge has no relation to the operating temperature of the oil in the dry sump system. While Spyder riders might like short little spins for wind therapy, the 1330 ACE engine doesn't like them and the results show in oil analysis reports.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Aug 2007
    Greeneville, TN
    Could be a sticking injector, too many short trips, idling too long when cold or lugging the engine. Good to have an analysis. Sometimes a good incentive to change bad habits. Sometimes just a clue to look into possible hard part issues.
    Mar 2021
    Ontario
    Thanks for the tips although 3% fuel in the oil is quite a lot and will see what the next oil change shows.
    Jim
