Results 1 to 19 of 19
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default B.E.S.T. Warranty NOT warrantying the stupid side bag door handles that break anymore
    We've practically all had our bikes in multiple times to get these cheap plastic sidebag latches replaced, and now I am being told that B.E.S.T. Warranty is NOT warrantying the stupid side bag door handles that break anymore??? Is anyone else hearing this? Can anyone confirm this? If this is true, it is class action time?
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    May 2013
    Apex, N.C.
    Quote Originally Posted by FINFAN3DP View Post
    I just had my 2021 RTL saddle bag handle fixed Friday under the BEST warranty. I had to pay the $50 deductible. The latch cost $38 and the labor charge was 1 hour. The warranty covered both.
    Danbury Connecticut
    A small piece of unsolicited advice. BRP gets very touchy when you start talking lawsuits. Especially when it's uncalled for.
    Remember, you catch more flies with honey than you do with vinegar.
    I broke a latch and just had my 2020 RTL side bag latches repaired and upgraded through a TSB. Show this to your dealer and explain that you're having difficulty opening the sidebags. They should do the work at BRP's expense, including repairing any broken latches.
    Once the upgrade is done, the sidebags open very smooth with little effort. Like BUTTAH.
    As always, my free advice comes with a double your money back guarantee.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Nov 2015
    Chardon, OH
    If you’ve already had the bulletin done, and have your stainless steel cables installed, then that’s the warranty work.
    https://static.nhtsa.gov/odi/tsbs/20...03706-0001.pdf
    If you’re breaking your handles because you’re reaching the end of travel and have to give it that extra yank to get it unlatched, then adjust the cable. Get down under the the saddle bag and look up into that open area behind the handle. The adjuster is up there and works just like any other cable adjuster.
    Doug
    ”Freedom is not a loophole”
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by Snowbelt Spyder View Post
    They have fixed these things several times, they always are so hard to open the plastic breaks. Not sure why can-am doesn't make a steel handle.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    Sounds like something the service guys should do.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Jun 2018
    HAYMARKET,VA
    Quote Originally Posted by ThreeWheels View Post
    "Uncalled for" being the operative words....
    Baja Ron Sway Bar
    Key Cover from Ebay
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Three Wheels, thanks for the TSB. I have replaced both handles and cables myself on the wife's 2021 RT. After confering with CAPTJAM his recommendation is that this should be added as a PM to adjust and lubricate the cables with EVERY oil change. Might be a little anal retentive but not a bad habit to get into. The handles and cables together are about $120.00 Just a thought FWIW, your results may vary. These cables live in a VERY dirty enviornment.
    Al in Kazoo
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Don't get hung up on words folks.
    Good advice. True...honey catches more flies than vinegar. Threating law suits over a small item like a luggage bag handle MAYBE a bit much. To me it sounds like the DEALER is giving you the run around, not the BEST warranty people. Dealers have been known to "fib" a lot these days.
    It is truly a pain that a $25K plus machine has parts that snap off and break. I do hope you can get your problrem solved to your satisfaction. Just be careful which bridges you may burn behind you.
    May 2013
    Apex, N.C.
    I wish I had seen this TSB and printed it out for them. I did ask them to check and they said there wasn't one. They printed out everything for my 2021 RTL and it said nothing about this. But I am glad it only cost me the $50 deductible to get it fixed. Would have been nice to keep the $50 though.
    Active Member USAF's Avatar
    Aug 2022
    NY
    Quote Originally Posted by blacklightning View Post
    You should be able to submit a claim with BRP to get reimbursed.
    2022 Spyder RTL
    Jun 2018
    HAYMARKET,VA
    UPDATE!!! It took weeks of arguing and sometimes screaming over the phone, but then one email to the President of Can Am, and i get this back:
    Thank you for contacting BRP. Mr. Boisjoli transferred me your email and I opened a customer service case.
    I spoke with Jason at your dealership (Moto Member) to better understand the warranty claim that was done. There was still an amount pending representing the handle which is not covered under the BEST warranty. I've approved a credit, under customer service, so that he can reimburse you the full amount $ 282.15.
    Baja Ron Sway Bar
    Key Cover from Ebay
    Aug 2018
    Piperton, TN
    Things should not be this hard.
    Feb 2012
    Spring City,Utah
    No they shouldn't......but they are and not likely to get any easier. I am glad your situation worked out for you. And thanks for letting us know.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    On my 2020 RT, I had my cables replaced by a dealer, showing them the TSB. Turns out that Can Am won't warranty it if the trike is out of warranty period. But the dealer covered it under "customer service" funds. My side cases open every time so very smoothly now....
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
    Danbury Connecticut
    Quote Originally Posted by BamaJohn View Post
    I'm sure that's what they said to you, but I'm calling BS on that. I think the dealer was either mistaken or trying to pull something off. Most likely they were mistaken. They didn't charge you, so they seem to be an OK dealer.
    IBA #47122
    Feb 2015
    Perhaps TSB's are treated differently than recalls.....my main point was that mine work flawlessly now, so the "fix" seems to work.
    John B.
    Feb 2020
    illinois
    One reason why I traded for a F3L- has better latching system.
    Oct 2019
    Florida
    Hey does anyone have the specific part numbers to order for the cables and handles. I have two 2020's that both have problems and our local service options are not good to be nice. It's just easier to do it myself. TIA
