Anyone replace the stock antenna on an F3-T or Limited?
If yes, what’s the secret in removing the stock antenna? I bought the stubby one from Lamonster, to fit under the IPS rack, also from Lamonster, and the directions say to twist to remove. It says it will be tight because of threadlock, but for the life of me, I can’t get that stinking thing off.
Try using a 7mm deep socket.... slide it over the entire antennae .... use a pair of vice-grips on the socket....turn it counter-clockwise..... Mike
Thanks Mike, I’ll give that a try.
I replaced mine with a stubby so I can get the cover on easier. I don't recall any problem with the change, but it was a few years ago.
Thunder's just the noise. Lightning does the work.
I used Mike’s method, but I used a 10mm socket. It ended up twisting the antenna in half, so I used needle nose pliers and I had to clamp them to the very bottom to break it loose. That thing was tough!
Got to love Loctite!! Clean the threads in the hole if you can with a tap and don't put it back together with the darn stuff, it will work better!
Was the reception any better?
2022 RT Sea To Sky
Me 2! I want to know if reception was better or worse after putting on the stubby?
On my Evo8 MR, I placed a 3-inch stubby on the roof in the factory location rather than the 14-inch factory whip and lost most of the reception. Went back 1 week later and used the factory whip and all was restored.
Reason: Caps & ' 's ;-)
2024 RT SEa To Sky ( back at dealer again due to blank screen issues , loss of BT and WIFI :-( :-( .. looking forward to the BajaRon event May 1-5 just with 2023 S2S only)
2023 RT Sea to Sky Shadow Green ( guess what NO errors at all in 9 months of owning....)
I replaced the one on my 2016 F3L with the stubby. It was about the same, or probably worse. Definitely not better.
Many years ago my OEM antennae broke ..... ( the Stubby wasn't available yet ) ... so I tried a Bosche manual retractable Auto antennae.... my reception increased by 400% ... This was on my 14 RT which isn't an F-3, so this option may not work for you .... good luck ....Mike
Used pliers and it came right off
I just changed mine out for a stubby antenna. I had to use vise grips to unscrew the stud, and yes, the loctite sure made it tough.
2019 RTL
No.
I have a 2023 F3 LTD Special Series.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
formerly pman2011
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
