Results 1 to 14 of 14
    Active Member Pikester's Avatar
    Rio Rancho, NM
    Default Anyone replace the stock antenna on an F3-T or Limited?
    If yes, what’s the secret in removing the stock antenna? I bought the stubby one from Lamonster, to fit under the IPS rack, also from Lamonster, and the directions say to twist to remove. It says it will be tight because of threadlock, but for the life of me, I can’t get that stinking thing off.
    2023 F3-T , Petrol Metallic
    Quote Originally Posted by Pikester View Post
    Try using a 7mm deep socket.... slide it over the entire antennae .... use a pair of vice-grips on the socket....turn it counter-clockwise..... Mike
    Rio Rancho, NM
    Thanks Mike, I’ll give that a try.
    Aug 2020
    California
    I replaced mine with a stubby so I can get the cover on easier. I don't recall any problem with the change, but it was a few years ago.
    Thunder's just the noise. Lightning does the work.
    Rio Rancho, NM
    I used Mike’s method, but I used a 10mm socket. It ended up twisting the antenna in half, so I used needle nose pliers and I had to clamp them to the very bottom to break it loose. That thing was tough!
    Durham,Maine
    Got to love Loctite!! Clean the threads in the hole if you can with a tap and don't put it back together with the darn stuff, it will work better!
    2012 RTL , Pearl
    Aug 2019
    Stoughton, WI
    Was the reception any better?
    2022 RT Sea To Sky
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Me 2! I want to know if reception was better or worse after putting on the stubby?
    On my Evo8 MR, I placed a 3-inch stubby on the roof in the factory location rather than the 14-inch factory whip and lost most of the reception. Went back 1 week later and used the factory whip and all was restored.
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
    May 2013
    Apex, N.C.
    I replaced the one on my 2016 F3L with the stubby. It was about the same, or probably worse. Definitely not better.
    Many years ago my OEM antennae broke ..... ( the Stubby wasn't available yet ) ... so I tried a Bosche manual retractable Auto antennae.... my reception increased by 400% ... This was on my 14 RT which isn't an F-3, so this option may not work for you .... good luck ....Mike
    Jul 2021
    Ontario
    Used pliers and it came right off
    Oct 2021
    TX
    I just changed mine out for a stubby antenna. I had to use vise grips to unscrew the stud, and yes, the loctite sure made it tough.
    2019 RTL
    2019 RTL , Blue
    Vermont
    No.
    I have a 2023 F3 LTD Special Series.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
