Not sure the plug is there anymore as the new models use smartphone integration. It won’t be long before smartphone are used in all vehicles. So much easier.
Look on the left side of the bike about even with the divide between the driver and pax seats. There will be a cap on the plug. The orange with violet wire is positive and the black is negative. You might have to clip some tie-wraps to get to it. This plug is only active when the engine is running.
I found mine on the left side panel of the bike just below the handlebars.
If you do a search on YouTube you should be able to find a video of installation.
Reason: insulation ...
2021 Limited , Brake pedal widened Glacial Blue Metallic
