Results 1 to 23 of 23
    Dec 2022
    Republic of Korea
    Default My motorcycle temperature is too hot.
    hello. I bought a 2023 canam spyder RTL this time. My country is hot for 7 out of 12 months.The average temperature is 30 degrees, with a high of 40 degrees. While driving Canam RTL, the sound of the fan repeating several times and the engine temperature is very hot. It was tolerable when riding the canam spyder f3, but the RTL is too hot...
    Is there any way to cool down my motorcycle? Shall I change the coolant on my motorcycle? Or let's remove the thermostats.. How can we cool down the heat.. Please help..
    indpls in
    do not remove the stats
    Dec 2022
    Republic of Korea
    Quote Originally Posted by fatboy View Post
    Oh....OK.. ok.. something is scary..
    Bossier LoUiSiAna
    Check radiator not blocked/dirty & fresh coolant not just diluted with water
    Dec 2020
    Hartwell, Ga
    Why do you think it is too hot?
    I assume that you are talking Celsius which translates to 86 to 104 Fahrenheit for us in the USA
    Lots of places here with those temps.
    Today's engines are designed to run at a certain temperature, messing around with that might cause some issues.
    Also, it is still under warranty if it is running too hot.
    You may be getting too hot. But I doubt your Spyder is getting too hot. If the fans are cycling, then I'm sure the engine is fine.
    The F3 is more of a 'Naked' bike design. Much more openness for ingress of fresh air and egress of hot air. The RT is more of an enclosed engine compartment and heat, because it will rise if nowhere else to go, ends up on the rider.
    Removing the 3 large plastic splash guards from underneath will allow additional fresh air in and hot air an avenue of escape. This also makes maintenance like oil changes much easier.
    Doing a Cat Delete will also reduce not only engine temperature. But rider felt heat. Especially at slow speeds. Then wrapping as much of the forward exhaust system as you can with exhaust tape will also reduce engine compartment and rider felt heat.
    Don't mess with the cooling system. As I said, I am sure it is working fine. What you need is reduced rider temps. There are improved coolants out there. They will get your engine temp down a little. But not enough to do what you're looking for.
    Sep 2014
    USA
    If you think a can am is hot go jump on a Harley. Your right legs will cook it self just sitting on the bike.
    I found the Spyder way cooler. On hot days it may get warmer but way more comfortable.
    You may also want to try air deflectors.
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    It's been 90° for a month of more here in Florida, I get hot, the 2022 RT-L runs just fine and the fans cycle constantly in city traffic.
    Give yourself time to get use to the new bike and as trikermuther said toss a leg over a Harley in 90° heat and you'll know real fast just what hot is.
    I have the same basic Spyder that you have .... it's a 14 RT, and last year I was stuck in traffic and the temp gauge was at 125 F .... but the motor Temp stayed at Four bars ..... good luck .... Mike
    Apr 2023
    FL
    Quote Originally Posted by kongdoly View Post
    Does the engine temperature gauge show overheating? It should be about mid-scale. That's from my experience in June in Florida USA.
    Chip
    2020 RTL
    "Stella by Starlight"
    Dec 2022
    Republic of Korea
    thanks for the good advice
    Dec 2022
    Republic of Korea
    I thought it was abnormal because it was so hot, but I guess it wasn't. Thank you for good information. I must run hard!
    Dec 2022
    Republic of Korea
    Quote Originally Posted by chipveres View Post
    The temperature gauge was medium. Sometimes it was so hot that reverse gear wouldn't work.
    Well, that isn't good. The shift mechanisms are down on the left side. They should not be affected, even if the engine is getting warmer than normal. Can you get away with removing the catalytic converter in Korea? Some just hog out the honeycomb, leaving the shell so it still looks like it is functional. Not as good as the Cat Delete because you still retain that huge heat producing can. But better than nothing.
    Dec 2022
    Republic of Korea
    After cat delete, the temperature improved to some extent. It was difficult to dissipate heat because it was equipped with a double Korean catalyst and silencer.!!
    Durham,Maine
    Now the rest of the tale!! Wow,double??
    2012 RTL , Pearl
    Dec 2020
    Hartwell, Ga
    I had originally thought that the OP meant that the bike/engine was getting hot.
    As a former mechanic/service manager I never thought about the OP himself getting hot. My misunderstanding
    So, you've already taken some measures to reduce the heat.
    Looking at the European, Australian, and Japan versions. They all have the same parts and part numbers as the North American RT for the exhaust system. Where is this 2nd catalytic converter located? Is there no way to eliminate it?
    I suggest you wrap both of those with " Heat Tape " .... it will help contain the Heat and improve " scavenging " the exhaust ..... Mike
    I don't think you 'misunderstood'. It is clear that the OP believes the engine is getting too hot being the root reason for why he is getting too hot. It is the respondents (or at least some) who speculate that the engine is operating within correct parameters. But a combination of design and high ambient temps are the actual culprit. None of us are there, so we can only speculate and suggest.
    Suggestions that he attempt to reduce heat generated by the Spyder are based on the fact that he did not experience this same degree of discomfort with his F3. A more open and heat dissipating format.
    Dec 2022
    Republic of Korea
    In Korea, the muffler was also equipped with a catalyst and silencer. So it was less noisy than a car. It was so quiet that people mistook it for an electric motorcycle when they passed by. HAHA...
    Dec 2022
    Republic of Korea
    oh thanks for the good info. I need to go catch up soon!!!
    Mar 2015
    forrest above Reno, Nv
    If YOU are hot-------- try a vented jacket with a cooling vest. A well-ventilated helmet and gloves help also. Carry extra cool water and use often. I also use an insulated cup, with straw, on the handlebars. Also have a vented windshield that helps keep me cool. I don't know much about high air temp here in Nevada
    Lew L
    Last edited by Peter Aawen; 07-03-2023 at 07:37 PM. Reason: Removed post title - many can't see them & they mess with Searching... ;-)
    2014 RTS , Circuit Yellow
