Results 1 to 25 of 28
    Active Member NorwegianRT's Avatar
    Apr 2022
    Southern Norway
    Default Just need confirmation before I use my tools ! Air compressor bypass.
    Just did 2796 miles from Norway to Austria and back on my 2012 RT.
    Second day home my compressor gave up, so kind of luck on the timing.
    To bypass the compressor, do I just need to disconnect the power on the compressor itself and the hub where all the tubes are connected ?
    I have marked what I mean with arrows on this picture.
    Brgds Martin
    Apr 2023
    FL
    Okay, I just looked at mine which is undergoing some repairs. If I wanted to disconnect the compressor and minimize cost I would do the following: Disconnect the hose from hub to the air bag at the hub end. Disconnect the hose from the Schrader valve to the hub at the hub end. Remove the non-return valve from the compressor and use it to connect the two hose ends. Into the air bag but not out. Or you can use an 1/8 inch NPT female coupling to connect the hoses. But these may not be easy to find in Norway. Put Teflon tape or pipe dope on each fitting. I don't know if this will upset Nanny.
    Chip
    2020 RTL
    "Stella by Starlight"
    Apr 2022
    Southern Norway
    Thank you for input Chip !
    I will try find a shop that might sell me what couplings I need.
    Not sure about the nanny myself.
    I'm sure someone will tell us.
    Brgds Martin
    Clinton, MS
    When you disconnect the wiring you will get an orange flag that drops down on the left side of the dash saying suspension fault. It will go and come. You will get an exclamation mark showing on the lower left side that will stay until you shut the bike off. It will come back as you ride again. I have not seen that it upsets the nanny.
    2019 RTL Phoenix Orange
    Durham,Maine
    I would just unhook the dump valve, go to an auto supply shop or a shop that may have big truck supplies and get about a foot of 1/4" air line for air brakes and a coupling for the air line. Then you unhook the line from the air bag where it goes into the dump valve; put your coupling on that end of the line; then unhook the Shrader valve from the system; and put the new line that is in that coupling to the end of your Shrader. Be careful when you pump it up, the bag's only good for 90 psi max, and it don't take long to get there; I use 60-70 psi in mine for two up riding! If you have some soapy water, I would check my connections for leaks; if it's tight, you shouldn't need to check it much. Good Luck! PS; by just unhooking the dump valve you shouldn't get lights or codes, I don't.
    2012 RTL , Pearl
    Apr 2022
    Southern Norway
    Thank you Mikey for a very good explanation
    Have to go to town today anyway, so I will try find a supplier for the needed parts.
    I think I have all the info I need for now and will get back to you all when I have hopefully resolved the issue !
    Many thanks to all who replied
    Brgds Martin
    Apr 2022
    Southern Norway
    Update !
    After watching a youtube video on how to replace the compressor, I saw that a different type was put in than the original.
    From what I could see, it was a "Viair 097 compressor".
    JB Tools had this at a nice price, so now it is ordered. All I have to do is replace the wire connectors with new ones as it comes with different solution.
    Said to be here in 5-8 days, so "I'll be back"
    Brgds Martin
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Let us know how it comes out !!
    Quote Originally Posted by NorwegianRT View Post
    Update !
    You might also hafta 'clock' the outlet on the compressor so that it sticks out towards the back of the Spyder rather than needing a hole cut in the RHS tupperware for it to stick out of; but IIRC, it's no biggie - just undo the (4?) screws holding the compressor head on, turn the head thru 90° (in the right direction ) and then put the screws back in.
    Oh, and the bits of rubber that hold the OEM compressor in are shaped to hold that specific odd flattened oval OEM shape, so they don't exactly fit the round Viair compressor quite so neatly - but they DO grip it firmly enough to hold it in place despite not being an exact fit, as many can now attest!
    Very Active Member taxmyzer's Avatar
    Jul 2013
    Bellmore,NY
    FYI- The Viair 97 was known to blow fuse due to higher (13) amperage. The Viair 95C (silver) or 94 (Stealth Black) draws same (10) amps as the OEM. You just need to drill and tap new holes to change direction of check valve.
    Ride safe!
    2022 Sea-T0-Sky
    Apr 2022
    Southern Norway
    Update!
    I canceled the Viair I ordered from JBTools today, could not get an approximate delivery date, so looked elsewhere.
    A Google search led me to a used original with hoses - valves and connections included.
    The price was good as well, and it will be here much quicker than the Viair (that I suspect they order from China/Aliexpress maybe)
    Also found an airscoop kit for my 2012 RTS and that will be here around the same time as the compressor!
    Brgds Martin
    Apr 2022
    Southern Norway
    Hi and thanks Peter !
    oi oi oi
    Posted an update here today.
    Brgds Martin
    Apr 2022
    Southern Norway
    Quote Originally Posted by taxmyzer View Post
    Hi Taxmyzer !
    Thanks for the info and advice.
    Posted an update today.
    Brgds Martin
    Apr 2022
    Southern Norway
    Update !
    Just got notice from JB Tools, my order is shipped !
    Just a few hrs after I wrote to cancel the order
    So now I will have a new Viair and also a used original compressor !
    I reckon I will mount the original one first as it is quicker and I get the RT on the road the soonest.
    And I will have a new compressor ready if/when the used one gives in.
    Brgds Martin
    Apr 2022
    Southern Norway
    Another update friends!
    The Viair compressor from JB Tools was dropped at my door today and I jumped in my work clothes and headed for the garage.
    Some tinkering to get it lined up without laying against the hoses coming from the brake fluid reservoir, but I found a nice position for it.
    I cut the wires from the old compressor to get use of the connection plug and soldered it to the new compressor wires and I remembered to put shrinking tube on before I soldered.
    All the tupperware put back on and I fired it up - put it in gear and handbrake off............... Compressor is alive and pumping
    But now I have a "brake failure" message on the display.
    Changed the brake fluid while waiting for the compressor and not sure what goes on now
    I have read that they are sensitive to the amount of fluid in the reservoir.
    I think I will call my local dealer and have them do a complete service on the brakes. They have the proper tools for the abs pump as well.
    The RT runs great tho and it was good to have the wheels back on the ground again.
    Have a wonderful weekend all and safe rides!
    Brgds Martin
    Durham,Maine
    Ya, you have to have that fluid right up in the bottom of the filler neck some times, only a cap full will put that light put! But if your not comfortable working with the brakes your doing the right thing. I will say that speed bleeders, are a wonderful thing to have, makes bleeding a lot easier.
    2012 RTL , Pearl
    Apr 2022
    Southern Norway
    Hi Mike and ty for feedback !
    I googeled "speed bleeders" and I think I will have to make a new order from the US as I can not find them over here !
    Brgds Martin
    Apr 2022
    Southern Norway
    Hi again friends!
    Final update!
    I pulled the C1282 (low pressure) code from my RT.
    Brakes felt fine and working perfectly, but still this brake failure on the display.
    Found a post concerning this code and found a way to reset it.
    Ignition on
    Hit mode button and put good weight on the brake pedal and hold it.
    Turn off the ignition and continue to hold the pressure on the pedal until computer shuts down.
    Stepped off the pedal and did a normal startup.
    And yayyyyyyy, the display is free of the fault message, and all is great!
    Now I hope to ride faultlessly for the rest of the season!
    Brgds Martin
    Sep 2014
    USA
    Or get aftermarket shocks and there no need for the air compressor. I got the M2 shocks and they hold up the rear end fine. Compressor has not turned on yet since they been installed.
    Apr 2022
    Southern Norway
    That is also an option of course, but I like the abilty to change softnes/hardnes by just a push on a button.
    I reckon it depends on how long this new alternate airpump lasts.
    Time will tell.
    Brgds Martin
    Apr 2022
    Southern Norway
    It happened for me as well, the Viair blew a fuse today, so wife and I took a U-turn and headed back home.
    Luckily, I had a spare used original compressor in the garage, so I decided to install that one instead. This being the fourth time taking the Spyder apart, it did not take that long time before the Viair compressor was out and the used original was in.
    Spyder is back on the ground and compressor works fine again
    Brgds Martin
    Durham,Maine
    Trust me, if you just bite the bullet and do the manual fill fix, you will not miss that adjustment button a bit, once you find the correct pressure for your type of riding. And the fix will only cost you a couple of bucks.
    2012 RTL , Pearl
    Apr 2022
    Southern Norway
    Trust me,that will be my next project when this compressor kicks the bucket. I prefer ride time over garage time
    Brgds Martin
    Apr 2022
    Southern Norway
    Btw, just to be sure !
    Is the manual solution similar to what it looks like in the box on the right ? Directly from the shraeder to the air bag. Or is it better to connect the "one way" valve from the compressor on the tube before entering the airbag ? That way it will be air in- not out !
    Brgds Martin
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    Your local Biltema store might know what speed bleeders you might need. They also stock vacuum bleeding systems.
    My Norwegian isn't up to much, well it isn't up to anything, but from what I can tell from their website they stock all kinds of things that might work for bleeding brakes.
    They have a website which seems to show all kinds of interesting things related to cars and motorcycles: https://www.biltema.no/
    Of course you probably know about them as they say they have 62 stores and mail order.
    The vacuum bleeder has part number: 19-1531
    Sorry if I'm telling you things you already know.
    Been a long time since I've been to Norway. Beautiful country and I would like to go back some day.
    Martin
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
