Results 1 to 20 of 20
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Default Want to replace Reverse lights with brighter LED's - any sources/part numbers?
    Does anyone have a good source and part number to accomplish this ..?
    Last edited by Peter Aawen; 06-10-2023 at 12:33 PM. Reason: Expanded title to briefly ask the question... ;-)
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Clinton, MS
    I installed these in mine a couple years ago. Almost as bright as the stock headlights.
    http://www.amazon.com/gp/product/B07...?ie=UTF8&psc=1
    Last edited by Peter Aawen; 06-10-2023 at 06:07 PM. Reason: Fixed link - you should just add the www. addr & NOT do anything else, the system will add all the URL stuff & duplicate it if you already tried! :-/
    2019 RTL Phoenix Orange
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    bad link
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
    Jun 2017
    Texas
    1156 type bulbs is what I found. I ordered some bright led 1156 type inserts on Amazon
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Dec 2012
    Murphy, NC
    I have bright LED’s as my brake lights. Probably 1156 bulbs. Much brighter than the stock brake and tail lights.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Clinton, MS
    Quote Originally Posted by seaweed View Post
    bad link
    Here is the product description.
    PHINLION 2800 Lumens 7506 1156 LED White Bulb Super Bright 3014 103-SMD BA15S 1156 7506 LED Bulbs with Projector for Back Up Reverse Lights, 6000K Xenon White
    A here is what it looks like.
    bad link
    Fixed the link.
    Holy moly those are bright ......Mike
    Dec 2012
    Murphy, NC
    I ordered the LED bulbs listed in the link above but they do not fit my F3 socket. The 1156 bulbs are too big in diameter. Has anyone found an LED reverse light to fit the F3?
    2020 F3 Ltd
    Spyderpops Bumpskid
    Nov 2013
    Central Texas
    EdMat, was this an easy install or a PITA?
    Clinton, MS
    Quote Originally Posted by JKMSPYDER View Post
    Check in your manual and see what size is needed for the F3.
    Clinton, MS
    Quote Originally Posted by oldguyinTX View Post
    It's not bad. The only hard part is removing the trim piece below the trunk. The sides that are below the passenger hand grips is a pain to get out and back in place with breaking the tabs off. Then it's simply unbolting the tail lights and pulling them out so you can get to the back side.
    Look up a YouTube vid on installing a trailer light adapter. That will get you right where you need to go.
    Jun 2017
    Texas
    I got rid of the incandescent turn signal bulbs and reverse bulbs with much brighter led replacements. Glad I did it. Made a big difference..!
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    I unfortunately did the same thing, now I get to return them. I have looked in the owners manual and there is NO information on any of the bulbs. I did a vehicle search on another website and it provided this same bad "too big" bulb. I took the bulb out and took a picture of it since the writing is too small to read and I believe it says 12356 on it but who knows if that's the equivalent of the 1156 or whatever the other bulb numbers are. I'm going to look around and see if I can find an LED replacement (so far no go). I have found a phillips non LED replacement, so I think I have the number correct.
    I think I found one on Amazon: https://www.amazon.com/VEHICODE-6413...2484583&sr=8-5
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
    Jun 2012
    Longmont, CO
    Here's another F3 reverse light LED but it uses more wattage, so unsure if it's a good idea or not: https://www.amazon.com/NSLUMO-LED-20...2484583&sr=8-8
    Jun 2012
    Longmont, CO
    Quote Originally Posted by vondalyn View Post
    EDIT: I think I found one on Amazon: https://www.amazon.com/VEHICODE-6413...2484583&sr=8-5
    I just ordered the ones above and they're due tomorrow so I'll see if they're the right thing then. Also just so all the replacement LEDs for turn signals/rear running/brake/turnsignal lights are in one place, here is what I've already used in our F3's.
    Rear: https://www.amazon.com/dp/B08H4MXQMZ...roduct_details
    Front: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    As far as hyperflash -- I have LEDs all over my F3S and when I first added some of them, I got hyperflash all the time and I was able to resolve it using Lamont's fix. With the new front turn signals and rear brake/running/turn signals, they are "normal/slow" when I'm stopped but when I'm moving they start normal and after a few seconds they then flash faster. I think I like that so I'm planning on leaving them as they are.
    Jan 2021
    Descanso, CA
    WRT RT installation as EdMat said
    The only hard part is removing the trim piece below the trunk. The sides that are below the passenger hand grips is a pain to get out and back in place without breaking the tabs off.
    Removing and replacing are about equal difficulty and risk to the front tab (both of mine were broken by the previous owner). What makes it a pain are the U-nuts. Maybe a quick spritz of WD-40 would help. The only solution that works for me is just to keep fussing moving each side back and forth, up and down. Then suddenly it pops out/in. Be patient.
    Feb 2012
    Spring City,Utah
    Remember on that trim piece there is a tiny tab in the center by the catch that has to be under the lip or your lid may be hard to close.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2012
    Longmont, CO
    The reverse LEDs in the amazon link above worked for the F3. Just installed and it's SO BRIGHT!
    Clinton, MS
    The link does not work. Looks like it's tied to a specific vehicle. Probably only you can see it.
