Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
  1. #26
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    BamaJohn, I think I discovered where you went wrong. The pic shows you putting the BB on the turn signal side of the switch. This pad is double sided. One side does the turn signals and the other does the shifting. You need to put the BB on the shifter side of the switch. Careful when you take the shift mechanism apart to change out the ball for the BB as there is a spring loaded detent ball that will come flying out. Fixed one today that way. I hope it holds up. Will try and do a better description later.
    Thanks EdMat. My photos might not be adequate, but I did put the BB on the shift side of the switch pad, but it stuck in the housing....wish I had you here back when this began
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
  2. #27
    Feb 2015
    Quote Originally Posted by Isopedella View Post
    So whats the correct size range?
    I measured the OEM ball bearings at 3.96mm
    John B.
  3. #28
    Jul 2023
    VA
    Sir, could you elaborate more on taking the shifter apart to place the BB on the correct side? I understand what you mean by the "double sided" switch, but I want to know more about taking the Shifter apart before attempting that. Is the spring-loaded ball easily put back in place? Did you replace both original balls? Thanks everyone for the posts all very informative. Could you perhaps add some pictures? Can-Am should take more responsibility for this obviously troubled part.
  4. #29
    Feb 2015
    Quote Originally Posted by F32018 View Post
    "EdMat" might have more info for you, but here's my update: After the original posting I wound up having to replace the whole switch assembly with new. The oem ball bearings in the switch assembly are smaller than a BB, so the BB would only work one side then sticking in place, disabling the other side of the assembly to work (I made it shift but lost turn signals, for example). Sorry I don't have better news.....
    Last edited by Peter Aawen; 12-27-2023 at 05:59 PM. Reason: Fixed quote display ;-)
    John B.
  5. #30
    Jul 2023
    VA
    Quote Originally Posted by BamaJohn View Post
    BamaJohn... thank you for the fast reply. Yes, I saw that earlier. I'm still thinking of a way to repair the switch. I'm thinking of a shim between the ball and the button it needs to push. Seems like a $450 switch assembly is hard to swallow. Also worried that it may just happen again. This happened with only 990 miles on my F3. Thanks again. Maybe
    Edmat can share some more thoughts? Thanks again.
    Last edited by Peter Aawen; 12-27-2023 at 05:57 PM. Reason: Fixed quote display ;-)
  6. #31
    Aug 2018
    north wis
    What about lead shot? Available in many size's well below BB.
    2020RTL
  7. #32
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by woods View Post
    Lead Shot - Bad Idea! You'll have more trouble than you Had!
    If in Doubt, Don't Do It!
  8. #33
    Clinton, MS
    Sadly the BB worked for a while, like every other thing I have tried. We are at the point now of replacing the whole left hand assembly. At the last failure what I found was, pressing on the switch membrane would no longer cause any function at all. It makes me think that one of the contacts is disintegrating. I won't know for sure until the assembly is replaced and i can tear the membrane apart.
    My thought now is that everything I have done to this point has been an illusion and the only thing that made a difference was every time we did something we caused a slight movement during reassembly allowing non deteriorated parts of the contacts to make contact.
    Not sure when he is going to spend the bucks for a new assembly.
    2019 RTL Phoenix Orange
  9. #34
    Jul 2023
    VA
    So the BB on the paddle side only worked for a while? I'm thinking about a small metal cap over the stud on the membrane. About 0.02 inches in thickness. If you ever saw a primer for a shell or a percussion cap for muzzleloader, think that type of cap. Pics show placement. As soon as it stops the torrential rain here in VA, I'll get outside to try something. Any thoughts on this idea? I concur with the lead bb being too soft and that it may cause other issues if it flakes inside the switch assembly. It needs to be a hard metal.
  10. #35
    I believe you have it correct. I had the same problem with my start switch.
    https://www.spyderlovers.com/forums/...=1#post1641755
    https://www.spyderlovers.com/forums/...t=start+button
    Finally ended up tapping into the appropriate wires outside of the RH switch assembly and connecting them to a push button which I installed where the OEM start button was located.
  11. #36
    Nov 2019
    Ontario
    Left Hand Multifunction Switch Assembly, 710008090 working for an F3-T 2019?
    2019 F3-t , Titanium
  12. #37
    Oct 2020
    Arizona
    This failing shifting issue creates a major safety issue. People in the US should take the time to fill out a complaint on www.safercar.gov . Maybe we can get an extended warranty going for the issue.
  13. #38
    Nov 2019
    Ontario
    The flat wire is broken inside
    Last edited by Peter Aawen; 03-17-2024 at 09:52 PM. Reason: Why 2 posts within moments?? :-/
