Results 1 to 6 of 6
    Active Member Wrongway's Avatar
    Jul 2017
    Tillsonburg Ontario Canada
    Thumbs up Can I remove clutter on screen of Zumo 590LM? I need help!
    I’ve searched on this forum as well as google as well as the operating manual for the zumo but can’t find the answer so here I am.
    When I set a destination or even just ride showing the map, it keeps showing me restaurants which really clutters up the screen when you’re in a town.
    So my question is how can I remove these or banks or parking lots etc.
    Thanks
    Greg
    Last edited by Peter Aawen; 05-09-2023 at 05:48 PM. Reason: Expanded title to briefly ask the question... ;-)
    Greg
    2015 RT Limited (White)
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    So you really went thru the Manual?
    Really?
    "You can customize which data appear on the map, such as icons for points of interest and road conditions.
    Select Settings > Map & Vehicle > Map Layers.
    Select the layers to include on the map, and select Save."
    If not there it should be in this section of Manual!
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Nov 2018
    Waynesboro, PA
    Quote Originally Posted by PaladinLV View Post
    Really?
    AJ
    Yes when you tap settings, then tap, map & vechicle, then scroll down to map layers, tap that, then tap, up ahead places. good luck
    My Spyder
    2012 RTL , Brown
    Jul 2017
    Really?
    AJ
    Yup. I really did go thru the manual
    Yup, really!!
    That said, thanks for your help AJ. Problem solved with your assistance. I couldn’t seem to understand Map Layers until you laid it our for me.
    Thanks again, issue resolved.
    Greg
    Jul 2017
    Quote Originally Posted by CopperSpyder View Post
    Thanks very much. I think it’s figured out now.
    Greg
    Bossier LoUiSiAna
    At least till an update
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
