Results 1 to 8 of 8
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    Default Setting belt tension - anyone converted 160lbs to newtons & used that?
    I know the consensus is to set belt tension to 160lbs with the wheel on the ground. Has anyone converted that to newtons, approximately 710n, and set the tension with the wheel on the ground to that tension?
    johnv
    Last edited by Peter Aawen; 05-09-2023 at 09:06 AM. Reason: Expanded title to briefly ask the question... ;-)
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Feb 2022
    New Zealand
    I do mine on the ground with my Krikit, where it counts.
    Adjusting where it runs I do with it in the air, then put it down and check the tension.
    Hope this helps.
    But im having trouble understanding your question.
    Online calc shows 160 foot pounds is about 216 newton meters.
    Where do you get 710 nm , its about 3 x .
    Jun 2018
    Tonawanda, NY
    The current spec states newtons, not newton meters, so I converted to lbs instead of foot lbs. I believe that this is the proper conversion.
    the current spec of 750 meters if calculated as newton meters would be 553 foot lbs, way too high for belt tension.
    johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    Jun 2018
    Tonawanda, NY
    From an earlier post
    "Torque is the measurement of rotational force. No rotational force in belt tension. The BRP spec is N (newtons, force) not N-M (newton meters, torque)."
    USMC RETIRED
    BLUE KNIGHTS NYV
    Feb 2022
    New Zealand
    Yeah ok.
    I have already suggested in post #2
    Hope this helps.
    Seems to be lost on you.
    Good luck. Moving on.
    Jun 2018
    Tonawanda, NY
    Some people have a hard time admitting they have misspoke, seems to be lost on you
    johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    Feb 2022
    New Zealand
    Um
    I said yeah ok
    See ya
    Harrington, Australia
    Quote Originally Posted by johnv50 View Post
    Ahhhhhh. Thanks John, the N, N-M difference always confused me. But I only use foot/lbs anyway. “N” it is
    HeliBars Handlebars
    Kenda Kanine rear.
