Results 1 to 9 of 9
    Sep 2020
    Philadelphia
    Default Bike shakes and shudders when I put it in gear - any ideas why?
    2012 RS - bike shakes as soon as I put it in gear, goes away when I hit the gas. Check engine light comes on sporadically....
    Need help! tia
    Last edited by Peter Aawen; 05-07-2023 at 11:29 PM. Reason: Expanded title to briefly ask the question... ;-)
    2012 Rs , Red
    Sep 2017
    Durham,Maine
    You got to give us some more information on the bike, mileage, what rpms it's running before and after you put it in gear, what have you done to the bike since you have owned it.... Things like have you replaced the two little hoses on your throttle body that crack; taken your evap can off; changed your plug wires and plugs; or run a can of carb cleaner thru the system lately? Help us help you!!
    2012 RTL , Pearl
    Sep 2020
    Philadelphia
    I haven't done any of those things before it started changed plugs since hoping it would help 39.000 miles bike idles around 1350 and 1400 regardless of gear thanks
    2012 Rs , Red
    Apr 2023
    Texas
    The idle speed seems high…like the engine is trying to overcompensate for a computer error.
    Since you changed plugs (and I’m assuming that you checked the air filter), my next guess would be O2 sensor going bad. After that, maybe plug wires.
    MOgang Member Yazz's Avatar
    Nov 2009
    Cypress, Texas
    Does the shaking and shuddering go away when the engine is revved in neutral as well as gears? If yes, then check your plug wires for arcing and sparking. Park your Spyder in a shady place, take off the front Tupperware so you can see the plugs and wires. Turn on the engine. If you see fireworks going off inside, the wires are bad.... Replace them with BajaRon's plugs and wires...... Been there, done that.
    Joy
    Very Happy Ryder...
    '09 Phantom and a '15 F3-S
    If you don't slow down, they can't catch you..
    ​If you don't give up, they can't win.
    What a long strange journey its been.
    Feb 2012
    Spring City,Utah
    If you did not change plug wires when you changed plugs then your plug wires are probably bad. The VTwin plug wires are notoriously fragile and the factory ones should be replaced at plug change. See Baja Ron.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2020
    Philadelphia
    Thanks guys I'll try the wires
    2012 Rs , Red
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Quote Originally Posted by Supaholaya View Post
    I would be inspecting your vacuum lines. High idle usually means a vacuum leak and the lines on your model are prone to hardening and cracking... BR should have replacements as well....
    Chuck
    Sep 2017
    Durham,Maine
    And by any chance are you smelling gas fumes when it parked in closed places? maybe time to rip the charcoal canister out of it. And one more vote for those wires, they should go together with dielectric grease.
    2012 RTL , Pearl
