When & what's needed for first Oil Change? 2022 RTL
I just realized that I might need to do an oil change on my 2022 RTL.
How many miles for the first oil change?
How many quarts does it take?
Which filters do I need? 2022 RTL
Reason: Expanded title to briefly ask the question... & Merged consecutive posts ;-)
Originally Posted by ahh-cool
which filters do I need? 2022 RTL
Did you not get an Owners Manual? It's all listed in the book.
2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
BaJa Ron Ultra 3 pcs sway bar kit
7jurock 25" tinted windscreen w/flip
Frogman Dave's "Signal Button"
If in Doubt, Don't Do It!
" Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
First oil change is at 3000 miles. Every 9300 miles or once a year, whichever comes first, after that.
Contact BajaRon for all your supplies.
Thanks, I always buy my stuff from BajaRon. Great customer service and prices
The XPS oil kit makes it easy as it has all you need. Owners manual has lots of info about the Spyder.
At 3000 miles I changed my oil and filter. I was very happy with having the filter and seal Baja Ron sent me. I noticed that one of my original drain plug o-rings was split so it was good to have those replacements on hand. I also found at this time my brake fluid looked like crap. I ordered a set of Speedbleeders for the front and rear calipers, purchased a quart of DOT 4 brake fluid and easily handled that job too. This forum has been very helpful and I appreciate all the great advice on how to care for and feed my Spyder.
2021 Spyder RT Limited Asphalt Gray Chrome Edition
2022 Spyder RT Limited Hyper Silver Chrome Edition
Spyderco Paramilitary 2
Vanquest Gen 2 7x10 First Aid Trauma Pack
Garage Door Opener
iPass
DJI Action 2
Tackform Anti-Vibe Phone Cradle
UltraGard Full Covers
Show Chrome rear trunk lid lift strut
Noco Genius 1
Noco GBX Booster X
Show Chrome Platinum Grande Adjustable Padded Driver Backrest with Storage Pouch
Baseus Cordless Inflator
I wonder how many people never read the owners manual? A lot of good info in it.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
By the time someone replies with everything you need to change the oil, you'll probably decide that you'll take it to a dealer.
Large socket, extension and ratchet for the filter cover. 36mm.
Small flat head screwdriver for push pin retainers.
Replacement mirror mounts if unlucky, or Slingmods magic mirror kit after removing the mirrors.
Torx bit kit for retaining screws on side panel.
Torx and allen bit kit for drain plugs, and probably replacement gold plugs so it's easier next time.
O-rings from dealer or BajaRon. What are there, 5 or 6? All different sizes. I use mine for 2 change cycles.
2 crush washers for drain plugs.
Get 6 quarts of oil, your choice, 10w40 for most, or if you think like me, 4 10w40, 2 20w50. Mine takes 5.25, some have needed a bit more. Review the other oil threads, there are as many opinions on oil as there are belly buttons. Some are innies, some are outies, and lots are full of lint. Castrol, Valvoline, Shell Advance, even the ubiquitous WalMart Supertech are all fine.
Oil filter, dealer, Amazon, or BajaRon.
3 hours of your time the first time.
I've been wrenching on bikes for over 50 years. This one is the most ridiculous I've ever changed oil on. BUT... the 998 original OG version was even worse, so...
WOW, I just realized I don't know how to remove the panels and mirrors on the new bike. I looked online for a video but couldn't find it. 2022 RTL
Oil change video from BRP is a how to … there are others easy to find with Google.
https://m.youtube.com/watch?v=HJUA1f...ature=emb_logo
Love my Spyders
2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
2014 RTS Circuit Yellow purchased 3/2/2018
2020 RTL Petrol Blue purchased 1/27/2023
Girls on Spyders #3195
No more 2 wheels
2020 RTL , Lamonster floor board riser Petrol Blue
No mirror removal on ‘22 owned by OP … this nuance replaced by another.
Love my Spyders
No more 2 wheels
If you were able to remove the panels on an older Spyder, it's easier on the 2020+ RTs. Once you do it and understand how they're removed, you're good to go. The mirrors never have to be removed.
Originally Posted by al0vely
Thanks for the video but it doesn't show how to remove that panel
I would recommend to have the dealer do the first oil change as they should also go back over the pre sale inspection to make sure everything is still good, after that do it your self unless you plan on doin the inspection and adjustments your self as well but you will probably need a manual for that. Plus they should do any new firmware updates that are needed.
