Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Mar 2021
    Haven, Ks
    Default Where do you carry your Spare key?
    So does anyone else take a spare key on a long trip. I have two factory supplied keys but am always afraid I will lose the main key I use in the ignition so I like to carry the spare. Problem is where do I hide it that I don't need a key to open up and get access? You can see from my signature line that I have a 2022 RTL Sea to Sky. The only unlocked storage is the glove box and I'm afraid that a fully programed key that close to the ignition switch will mess up the computer. Thought about wrapping the spare in tin foil and putting it in the glove box but what does everyone else do????
    Last edited by Peter Aawen; 05-01-2023 at 06:43 PM. Reason: Expanded title to briefly ask the question... ;-)
    Bartender
    2022 Spyder Sea to Sky
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    Put it in a magnetic key holder and attach it to the engine out of sight.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Quote Originally Posted by Bartender View Post
    I keep spare #3 in the Frunk, I have access to the Frunk using a separate PULL cord ..... good luck .... Mike
    Apr 2023
    FL
    One problem with our machines is that the plastic compartments are awfully easy to break into. Two suggestions: Search "hide key" in the search box of this site. Or safety-pin the spare to the lining of your jacket.
    Chip
    Apr 2019
    Florida Swamp
    Open one of the access panels and tape it to a wire or bundle of wires that are normally out of sight when the panel is open.
    You can clip the tie wraps holding the bundle out of the way (out of sight) then put a new tie wrap on it after the key is taped to it.
    Use electrical tape. Nothing real unusual about electrical tape on a bundle of wires.
    If you need a special tool to open the access panel, keep that in the glove box or tank bag.
    2019 F3-S , Black & Silver
    Very Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    I always carry a spare key.
    Ripley's believe it or not....
    I put it in my pocket.
    Bossier LoUiSiAna
    1 In wallet on my person 1 with family just phone call away
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2016
    Chillicothe, Oh.
    I carry one of the factory keys and my wife has a key that we had cut at our local hardware store. My DESS has been disabled so her key will start the Spyder. I take the two wheeler if traveling alone, but if for some reason I take the Spyder I put the cut key in my wallet behind my AMA card.
    2015 RT , Black
    Active Member linguine's Avatar
    Feb 2023
    AZ
    Doesn't the glove box lock when you turn the wheels all the way right or left, and then turn the key all the way to the left [not pushing down]? I thought they all did that...
    Ride safe; shiny side up, greasy side down.
    best,
    linguine
    2020 RT Limited , Chalk Gray
    Aug 2020
    California
    Umm - how about your pocket?
    Thunder's just the noise. Lightning does the work.
    Very Active Member rjinaz86323's Avatar
    Mar 2021
    Arizona high country
    Depends if riding solo or not. On a lanyard around my or the wife’s neck
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2018 F3 Limited - Intense Red Pearl . . . . . . . . . . . . . . . . . . . . . . . . . . .
    Sep 2017
    Durham,Maine
    Most of the time if I am in Maine, I just leave it in the switch! If someone wants it they will get it, one way or another. And there will be a helmet sitting there for them to put on also, sitting over it.
    2012 RTL , Pearl
    Sep 2016
    N.E. Ohio
    Haven't done anything with the Spyder yet but in the Harley, I have a non-chipped key hidden to access the trunk. In the trunk, I have hidden a programmed key wrapped in aluminum foil so it's not being read by the security system.
    Feb 2012
    Spring City,Utah
    Years ago I could start my '72 BMW with a nail, so I got in the habit of leaving the "key" in the ignition hole. Although I do take my key out of the ignition and lock my cars here i Utah, I don't take the key out of the Spyder. I just put my gloves on top of it when I park it. I actually never carry a spare key. I hope I didn't just jinx myself.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Aug 2013
    SF Bay Area
    My spare is in the trunk. I have a flat key cut so it unlocks the trunk in my wallet. It can unlock the trunk and saddlebags and I get access to the spare.
    2021 F3 Ltd , Magna Red
    Active Member RodO's Avatar
    Jul 2009
    Montréal, Canada
    I used to carry it in the inside pocket of my jacket, but when I'm stopped for a break, I leave the jacket on the seat so not a good plan.
    I've just started using a leg bag so my phone, SPOT tracker, spare key, and registration stay with me.
    The key I'm using goes onto a lanyard around my neck when I'm stopped, along with a USB with my ICE info (In Case of Emergency).
    Ryde safe,
    Rod.
    '08 GS SM5 Full Moon -- after 15,000km sold May'11
    '10 RT A+C SE5 Full Moon -- after 30,700km traded in 2014
    '17 RTL Pearl White -- new-to-me in 2023
    "I guess its better to bend a valve in Missoula than to lose your mind in Bozeman", my wife said, patting my hand as if to console me. I winced and wondered if Phaedrus ever took the bus." -Peter Egan, Leanings
    CanAm Highway goes from Texas along U.S. Route 85 and Interstate 25 into Saskatchewan, Canada.<http://en.wikipedia.org/wiki/CanAm_Highway>
    Jun 2021
    OR
    There are several places you can hide a key. Some people have a non-chipped key somewhere easer to get to and the chipped key some place harder to get too. You could have a non-chipped key taped to the back of the glove box when pulled out as long as you do not plan to lock your handle bars as this locks the glove box too or behind the speaker grill, or behind one of the side panels. Then hide the chipped key in the frunk somewhere.
    2021 Syder RT Limited
    Oct 2021
    Wichita, KS
    At home in a drawer where all of my spare keys/fobs are. If I were on a long trip (and remembered to think about it) I would probably carry a spare in my jeans pocket.
    Peter Pan has struck again!
    Jul 2014
    Mint Hill, NC
    The well known Ilco X270 unchipped key beveled as shown in the picture allows me to open any locked compartment on my Spyder and even set and release the parking brake. It resides in my wallet that is never off my person. I keep a second chipped key...
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Sep 2016
    Chillicothe, Oh.
    And if DESS is disabled these keys will start the Spyder.
    2015 RT , Black
    Jan 2019
    Hunter Valley NSW Australia
    At home in the key safe. If I am on a long trip and lose it I'll have our daughter call in home and send it to me
    2017 RTL
    2017 RTL , White
    Sep 2012
    Stetson, Maine
    Mine is on the Spyder somewhere. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Jan 2019
    This is a top idea.... calling into the locksmith today.
    2017 RTL
    2017 RTL , White
    Jan 2021
    Monroe, la
    Since mine has to have a chipped key hidden plus I can open the frunk and seat without a key.
    2010 RT
    2015 Ural
    1980 & 1982 R65 BMW
    1975 R90/6 BMW
    1956 Triumph TR3A
    Vermont
    I carry my spare key with me in my jacket.
    I don't hide the spare key any where on the
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
