Results 1 to 9 of 9
    Apr 2023
    Calgary Alberta
    Spyder What LED's to replace the OEM HID lights - Low, High, & Fog?
    Good day all,
    I was inquiring what would be the correct LED bulb to fit when I change out the original Hid's? Looking to change out the low, high, and the fog lights. Just newly picked up a 2014 Spyder RT recently; thanks to all for any thoughts.
    Last edited by Peter Aawen; 04-30-2023 at 08:58 PM. Reason: Expanded title to briefly ask the question... ;-)
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    Fahren from Amazon is what i bought work good.
    Jan 2021
    Descanso, CA
    gvs1 -- the lighting fixtures differ among countries. In the US my Spyder uses the upper lamp fixtures as combined Hi/Lo beam with single filament bulb and with a shutter controlling beam shape. I wanted 4500 Kelvin color temperature so HID is working well for me. But if your Lo beam fixture is separate from your Hi beam fixture then HIDs won't work due to the long delay (1-2 seconds) for warmup unless you use a delay relay to provide overlap. And with the supporting electronics HID installation isn't for the faint-hearted. So I think LEDs will be your better choice.
    PS in 2014 BRP used incandescent bulbs for head and fog lights. No HIDs or LEDs.
    Apr 2023
    Calgary Alberta
    Thanks for your thoughts, could you confirm if a 9005 HB3 led light be the correct one? Yes, I also read that LED were not available for the spyder back in 2014.
    Jan 2021
    Descanso, CA
    I checked my service manual and apparently Canadian Spyders used a single Hi/Lo lamp fixture with shutter. To replace the incandescent bulb I suggest you start here https://www.lamonstergarage.com/lighting-2/?page=2
    Apr 2023
    Calgary Alberta
    Thanks again, Ill check into it further.
    Quote Originally Posted by helton61 View Post
    I have them also and mine light up the night .... with very good projection and enough spread ... mine are rated @ 16,000 lumen's .... they have more powerful ones ....and I paid $45.00 per pair .... good luck .... Mike
    Quote Originally Posted by gvs1 View Post
    I also have a 2014 rt and they work great ..... Mike
    Jan 2023
    Virginia
    It was your post is the reason i tried them.
