Results 1 to 7 of 7
    Very Active Member vtrider's Avatar
    Jul 2008
    Cambridge, Vermont
    Default New BajaRon Ultra sway bar installed
    Today I installed my new Ultra Sway Bar that I ordered from Spyder Pops for my new 2023 RT Sea To Sky. The install took me some time, but it went well otherwise. I had to lift the front end of the Spyder to get it up to the 24 inch clearance that I needed to remove the OEM sway bar. The way I did this was, lift it with my Kioti tractor bucket loader with the fork lift attachment. I lowered the forks at ground level on the garage floor. I then drove the Spyder onto the forks to the front of the loader bucket where the fork lift bracket attaches to the bucket loader. I started the tractor and carefully lifted the Spyder keeping the forks slightly angled up so the Spyder would stay positioned to the front of the loader bucket. I made sure to lock the hydraulic control lever on the tractor and secured the loader bucket and the fork lift arms with jack stands. I also put wheels chocks on the rear tire for added safety. It looked a little scary at first, but it worked out very well. It sure made it easy to do the work needed under the Spyder to get the new sway bar installed. Once completed, I took the Spyder for a test ride and was very happy with the performance of the new Ultra Sway bar. It really is an improvement over the OEM sway bar for handling and control.
    Vermont
    Thanks for the pictures.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Aug 2022
    West Virginia
    Baja Ron Ultra!
    I will admit I was a little skeptical about the benefits of a new sway bar. I have a 22 F3L and often ride with a buddy that has a ‘15 RT. When he’s following me he remarks about how much less lean my bike seems to have compared to his. So I thought I had it pretty good.
    But, after reading a lot of posts here, I decided to try the Ultra bar based on our 2-up usage (and the combined weight 😏 ). After just one day all I can say is WOW!
    Somebody on here said this should be the first upgrade anyone makes.
    Amen! It’ll be some of the best money you’ll spend.
    Last edited by Peter Aawen; 07-11-2023 at 10:58 PM. Reason: Moved Post title into text after merge - many only see Thread titles, and post titles mess with Searching! ;-)
    2022 F3L , Lamonster Brake Rod Glacial Blue
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    It was a game changer for sure.
    Jan 2021
    northeast pa.
    Quote Originally Posted by Hhilljr View Post
    Baja Ron Ultra!
    But, after reading a lot of posts here, I decided to try the Ultra bar based on our 2-up usage (and the combined weight �� ). After just one day all I can say is WOW!
    if you think that made a differance, get some quadtracs up front..
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Durham,Maine
    Now that's using your noggin, glad you used your jack stands. I will admit that was one of best things I did to my ride, along with the shocks!
    2012 RTL , Pearl
    Aug 2022
    West Virginia
    Quote Originally Posted by fredgal View Post
    I've been looking into those as well, and researching Elka shocks.
