Results 1 to 5 of 5
    Jan 2023
    RI
    Default Passenger Grab Rail heating gets barely warm, any ideas?
    2022 RT Limited. The passenger heated grab rails are just barely warm. In addition, I noticed that the lighted rocker switch for the grab rails when turned on, glows at about 1/2 the intensity of all the other lighted switches.
    Any thoughts or ideas?
    -- Paul
    Last edited by Peter Aawen; 03-03-2023 at 04:44 PM. Reason: Expanded title to briefly ask the question... ;-)
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    have you checked the connections on the back of the switch and on the grips themselves.
    sounds like a bad ground of lose connection.
    Active Member PJveetwin's Avatar
    Oct 2022
    Peoples Republic of Calif. Upper Mojave Desert
    The one on my 22 RTL does not get anything close to the rider grips. Seat does, just thinking it is what it is.......
    2021 RT LT
    Jan 2023
    RI
    Quote Originally Posted by SLICE View Post
    Thanks for the reply. I'll try and do that soon. Easy fix if that's the issue.
    Jan 2023
    RI
    Quote Originally Posted by PJveetwin View Post
    Thank you. Yes, the seat is quite warm, but not the passenger grips.
