Results 1 to 8 of 8
    Feb 2023
    South Georgia USA
    Default Should there be 2 Headlight Adjusters? 2016 RT LTD
    on my, new to me, 2016 Spider RT Limited, it had one adjustment cable on the left headlight globe but none on the right. Leaving me with the question Should there be one on each side or just one on the left side?
    Hank
    Last edited by Peter Aawen; 02-26-2023 at 02:43 PM. Reason: Expanded title to briefly ask the question... ;-)
    Jan 2021
    Descanso, CA
    Talking Two
    From my owner manual
    Headlights Aiming Adjustment
    1. Remove both side panels. Refer to
    BODY PANELS in the EQUIPMENT
    subsection.
    2. To adjust headlight beam, turn the
    adjustment knob. Adjust both head
    lights evenly.
    The owner manual seems quite clear there are two adjusters.
    Quote Originally Posted by HanklovesJesus View Post
    Hank
    My 14 has TWO ...... Mike
    Jan 2015
    southern WI
    my '16 had 2. Did someone do some work and forget to put the adjuster back in its place?
    2016 RTS , Pearl White
    Durham,Maine
    should be two
    2012 RTL , Pearl
    Mar 2017
    Salisbury,NC
    will be 2. somebody just had the side panel off and didn't put cable thru hole. or big nut fell off and cable slipped inside. it should be still attached to light housing
    Did you see our responses when you asked about this about two weeks ago? https://www.spyderlovers.com/forums/...is-this-normal
    INDIANA, USA
    Default Two
    ..... Diffently Should Have a Cable Attached to Each Light Fixture.
    ENJOY YOUR LIFE WITH A SPYDER
