Results 1 to 7 of 7
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Default Rock -- Crunch -- LH skidplate gone...
    I hit a rock the other day and I'm not quite sure what happened. It wasn't a big rock and looked like the foot-over-the-rock technique should have worked. But, I think I ticked it with the left front tire and sent it under the chassis on edge.
    The result was a shattered LH skid plate. I was excited when the part cost less than $25, but none are available. I'm thinking about a truck mudflap screwed to the frame as a substitute. And (oh yeah) the front cross member of the frame is bent. Looks to be easily straightened.
    My son (the expert fabricator) is going to look at it with me. He makes aluminum skid plates for motorcycles, so I'm getting expert advice.
    Sure would be simple if parts were available.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    2020 RT , Lamonster extender Petrol
    The "parts" situation is a very real concern to many.
    Dec 2013
    Quote Originally Posted by ButterSmooth View Post
    I dunno about screwing anything to the frame, not if it entails adding screws/holes...
    Your son might be able to help with the best solution - one of them to go under the entire front/lower section would be a good idea (Ron/noboot makes/sells an alloy skid plate too) only if he's fabricating a new design for you, DON'T let it project beyond the edges of the tupperware (as in 'Bumpskid' style!) cos if you do and you hit any of the projecting bits on anything solid, the repair bill can be expensive!!
    Glad it didn't do any more damage tho...
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Sep 2020
    Central Oregon
    ... I dunno about screwing anything to the frame, not if it entails adding screws/holes... ...
    This is a pre "expert advice" comment, but I'm thinking of making those ~8mm holes for push-pins just like stock. The drilled hole would have to be rust proofed with appropriate coatings, of course. And it is the t-bar lateral members of the frame, not the 'box'.
    Spyder Tryke Pylot
    Jan 2021
    Descanso, CA
    May I suggest rivet nuts for both your new openings and the pushpin openings. And then use stainless steel flanged button-head hex screws. Works a treat for me!
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    I agree with Bert on this, thes make work afterwards a lot easier, but don't drill holes in the frame...
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Sep 2017
    INDIANA, USA
    Default No Drilling In Frame
    Quote Originally Posted by Piratezz View Post
    NEVER DRILL ANY HOLES IN THE FRAME.
    Until you get permission in writing from the frame
    Manufacturer.
    Just a little legal issue. ....
    I will let you decide what you will do. ......
    Stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
