RT-S PE#0256 SyderLovers Sponsor
Fuel Line Chafing on my Spyder
I really hate all the bad press going on because I love my Spyder and so does my wife! I hope this is actually some useful information that can use this forum in a positive way and Maybe help with one of the big issues. Whether this is relevant or not, I can not say for sure, but I think it is relevant enough to mention. I normally inspect fuel lines, water hoses, oil lines, etc for chafing when I do routine maintenance. Maybe lots of folks do, but some of these habits come from my aircraft background.
Anyhow, I found a spot on my Spyder where the fuel line rubs on the cylinder head right at the seam between the valve cover and the cylinder head. There is a bit of a sharp edge there. Now there is not much rubber missing on my fuel line, but there is a definite scoop of rubber missing. I have about 7k miles on mine, and IF your valve cover edge was a bit sharper (easily could be since its the edge of a casting) and if you have alot more miles, or if your fuel line is rubbing harder, there is a possibility this could penetrate all the way through over time.
I will be putting some chafing gear on my fuel line in this spot, and replacing the line.
I really hope this helps, I would encourage others to take a look at this spot. Just take off the right side cover with the 4 6mm torx screws and it's right there. Feel behind your fuel line with your fingers. It will be interesting to see what people find. If anyone finds a fuel line worn through even more than mine......please post.
Hope this is helpful,
Mad Matt
Motorbike Professor
Firefly pointed this out a while back. I inspected mine and found the same thing, so I covered it with split loom. The newer Spyders already have this corrugated tubing cover. Thanks for the reminder that it is essential to carefully inspect all the details of a motorcycle periodically, including all fasteners, tires, suspension components, safety equipment, electrical wiring, and fuel systems. If you haven't done this lately owners, especially owners of 2008 Spyders, do it now! The Spyder you save could be your own.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Blazing Member
with Scotty. Just checked mine 09 SE and the fuel line has the plastic loom over it.
+1
My 2008 SE5 was built in November and has the split loom on the fuel line.
I think that this is an indicator that BRP has at least some rudiments of a Quality Improvement Program in place which is why I think that eventually they will get the steering problem(s?) solved.
Still good idea to check around in there on a regular basis with your hand on the tubing as what you can't see on the backside of the hose/wiring is what will get you.
A member of the rabble in good standing.
A happy owner of a yellow SE-5.
NMN Risers, Mudflap Lights, Fender Tips, Center Brake Light w/ Triple Play, Throttlemeister, Madstad Robo-brackets, Madstad windshield, CHAD windshield, Canisterectomy, Exhaust wrap.
Senile Member
Originally Posted by Latemarch
+1
I wonder why BRP didn't put out a service bulletin to loom up the earlier '08s? The guinnie pigs are expandable?
Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
...calculated casualties...
2013 "Silver Dream" GG Taurus
2008 "Silver Dream" Spyder RS
Einstein's theory of drag racing: Time and Speed are Relative.
Shut up and Race!
My 2008 SE5 built in June of 2008 has the split loom on it so I would guess that BRP figured out relatively early that the rubbing could be a problem.
HAPPY 2008 SE5 OWNER 1" BRP Riser, NMN 3" risers, NMN Triple Play & Tail Light, Kewlmetal Mirror Extensions, Evoluzione Powerbus, BRP 23" Touring Windshield on CHAD Bracket, Ride-On in tires, J&M Integrator, Gerbings Dual Zone Temp Controller & Heated Gloves, 2 Dash Mounted 12V outlets, Kewlmetal Highway Brackets & Kuryakyn pegs, Trunk Spring Mod, Vista Cruise Throttle Lock, Kuyrakyn L.E.D. Battery Guage
Motorbike Professor
Sounds like it. Our PE Spyder built in February of 2008 had no protective cover.
-Scotty
Because if they had to add a .22 cent piece of tubing over the fuel line of every "early build Spyder" think of what it would cost them
The simplier, less costly solution is just to write off the fire issue, close the book on it, and deny all responsibility.
Penny wise, but pound foolish....it will come back to haunt them, just wait and see !!!
Fond memories of the ford pinto
This was a very helpful post... until the BRP bashing started. Those so unhappy with BRP really ought to sell their Spyders and buy something from another manufacturer they can complain about.
08 Spyder SM5, Phantom kit, Hindle exhaust, otherwise stock
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
Number One: 2008 Yellow GS SM5. I love my Spyder.
Number Two: 2012 RT-S Limited (the poop colored RT) I still have Number One, but Some Girl made me buy Number Two...
Yellinacha
Senile Member
Looms are cheap. Harbor Freight have big bags of them things for peanut change. Will cover all the fuel lines this winter when the Spyder is all apart. I might even go ahead and wrap the exaust.
Yellinacha
Abrasive Rub Is There!
Yep .....At 7k mileage I have same abrasive dish out in exact same spot.Will be loom wrapped before next ride!!
Tis a shame we have to be so pro-active in knocking out punch list items that are concerning!Has anybody tallied the 08 vs 09 model fires??I have not kept track but wonder if one year is weighted over the other??
Or in military terms, "acceptable losses".
Bruce
Bruce Brown
London, Ontario, Canada
Spyder Ambassador (Ret.)
2009 Moto Guzzi Stelvio "Silvia Dionisio"
Help us fight prostate cancer: http://motorcycleridefordad.org/
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, 'WOW, what a ride!'"
Anybody want to bet on the guy who's spyder got on fire in his garage this might have been the problem ...If i remember right thay dident find out on what started the fire. my facts maybe wrong but its been a while sence i think it was sometime this early summer
To avoid these issues, I got a piece of lead line the stuff used to secure chain link fense to the post. I bent a piece into a line holder and fastened it to the hole on the cylinder head bracket. It holds the line away from the motor and prevents rubbing 5 minute job and about 20cents.
2008 SM5 Yellow, built 5/08 Mods: Evoluzione CAI, and Programable SPAL Fan. Two Brothers Juice Box, Hindle Exhaust. Custom Dynamics Lighting and Mono seat Cowl.
2012 RSS SM5 Red/Black Mods Two Brothers Carbon Fiber Exhaust Dynojet Power Commander JT's Custom Air Filter.
