Results 1 to 18 of 18
    Active Member slhanks004's Avatar
    Nov 2022
    Gilbert, AZ
    Default YANOT (Yet ANother Oil Thread) 22 RTL - anyone tried Mobil 1 Turbo Diesel oil?
    Hi,
    I am coming up on my first oil change for my 2022 RT Limited. In researching oil, the owner's manual states:
    "Use a 5W40 4-stroke SAE synthetic engine oil meeting or exceeding the
    following lubricant industry specifications:
    API service classification SJ, SL, SM or SN"
    I know about Rotella T6, and used it for years in my Kawasaki Nomad. I am curious if anyone has tried Mobil 1 Turbo Diesel Truck Full Synthetic Oil? I tried to search on here, but didn't find any results.
    The label on the oil says it's API CK-4, CJ-4, CI-4 PLUS, CI-4 - API SN, SM.
    If anyone has any insight on this product, I'd appreciate hearing it.
    Last edited by slhanks004; 01-30-2023 at 09:48 AM. Reason: Expanded title to briefly ask the question/state a purpose for the thread... ;-)
    Scott (slhanks004)
    Gilbert, AZ USA
    2022 Spyder RT Limited - Carbon Black
    • Pedal commander
    • Baja Ron sway bar
    • TricLED tail lights
    • TricLED driving lights
    • Corbin seat
    • BRP rider backrest
    • Lamonster topcuff (2) w/ RAM mounts
    • 12v/USB docking station
    • Garmin Zumo XT
    • RLS cat delete pipe
    • IPS highway pegs
    • IPS belt tensioner
    2022 RT-L , Carbon black
    Quote Originally Posted by slhanks004 View Post
    Hi,
    specifications:
    SM or SN"
    I anyone has any insight on this product, I'd appreciate hearing it.
    That Rotella is ....PERFECT .... for your Spyder ..... since you live in a warmer climate State I would use the 10-40 version. ..... Annnnnnnnnnnnnnnnnnd if you buy it at Walmart your likely to save money ..... PS the Rotella is also JASO MA II rated and that's as good as it gets ..... Mike
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    Any quality oil that meets the manufacturers specifications is fine. I too use the Rotella, but use 15W-50 because of the heat in North Carolina.
    2015 F3S SE6
    Oct 2020
    Vinton, IA
    Works great for the engine in my John Deere but, the wet clutches in the trans & PTO require different oil. I would not put it in my RTL. Besides that, it's about $35.00/gal (+/-) at Walmart and there are many, more reasonable alternatives out there.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Quote Originally Posted by spyderdave View Post
    Well The REAL price at Walmart is actually $ 24.73 ( today - on-line & at the store ) ..... annnnnnnnnnnnnnnnnnnnnd I believe JASO II is the highest rating any oil can have ...... just sayin .... Mike
    Oct 2020
    Vinton, IA
    My apologies, I was not referring to Rotella. I thought the original question was regarding the use of Mobil 1 Turbo Diesel; which, according to the Mobil website, does not include a JASO II rating.
    May 2013
    Apex, N.C.
    This "turbo diesel oil" must be the best stuff on the planet! I have owned and been on many forums (M109, 2nd gen Vmax, BMW K1600, and Mustang), and they all have at least 2-3 threads talking about how this stuff is there go to oil. It is kinda like the cure all for any engine. I personally will stick with what is suggested in the owners manual, at least until the warranty is out on my vehicles. But good luck.
    Nov 2022
    Gilbert, AZ
    Thanks, but $35 a gallon isn't exactly out of reach. Look at what BRP charges for their oil!
    Scott (slhanks004)
    Gilbert, AZ USA
    • Pedal commander
    • Baja Ron sway bar
    • Corbin seat
    • Garmin Zumo XT
    • IPS highway pegs
    Aug 2007
    Greeneville, TN
    It needs to be a JASO MA2 rated oil, as Mike states. Just about anything will do you better than the OEM blended oil, as that breaks down fairly quickly. But JASO MA2 is imperative.
    Oct 2016
    Sebring, FL
    How true, and the BRP is blended, which is fine, but for the price? I'm a T6 user, but everyone has a choice.
    Aug 2007
    Greeneville, TN
    Blended means you're getting 10% synthetic and 90% mineral oil. I compare it to taking 10% of the finest artesian spring water and mixing it with 90% tap water. Would you buy this drink?
    This is why BRP's blended oil begins to break down quickly after 4,500 miles. And why the original oil service interval was 4,500 miles.
    Now it's your machine. And I fully support owners doing what they think best. But it doesn't hurt to make choices based upon all available information.
    Aug 2019
    Stoughton, WI
    Actually, there is no API standard for synthetic blend motor oils. It is generally thought that synthetic blends will contain no more than 30% synthetic content. There are no industry standards for minimum amounts of synthetic content.
    2022 RT Sea To Sky
    Aug 2007
    Greeneville, TN
    That is true. And since BRP gives no specs on their oil, it is hard to know. However, the great majority of blended oils are in the 10% range. It might be that the BRP oil has 30% synthetic. But the fact is, it begins to shear quickly after 4,500 miles. This has been documented with a number of tests.
    Last edited by Peter Aawen; 01-31-2023 at 04:32 PM. Reason: Fixed quote display ;-)
    Active Member Hound's Avatar
    Oct 2017
    Eastern ND
    I like the T6 when I had a couple of Kawasaki Vulcans and now for the Spyder as well as the John Deere 4600 that is currently moving the snow while the RT-L is on the table going through installation of TriAxis handlebars, LED headlights and a Pedal Box.
    2016 RT-L , Blue
    Mar 2013
    I have had difficulty trying to source T6 from Walmart, but just sourced 3 gals from Home Depot in Apache Junction. Price is close to the same as Walmart. Since I have two RT's to do I need 3 gals each time. I purchased my filters from Baja Ron, and take the used oil to Walmart for disposal as they will take up to 5 gals per trip.
    I have been using T6 in all our Spyders since or 2014 RT ( it had 84,000 miles on it when we traded it in), and our 2021 has 37,000 miles on it with our 2020 having over 61,000 miles on it.
    My change interval is every 9000 miles after the frist 3000 mile change. Never had any engine oil related problems.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Dec 2021
    Oregon
    Mobil 1 FS European Car Formula 5W-40 Full Synthetic Motor Oil, 5 Quart
    WALMART $29.97
    [img]
    Idaho
    Quote Originally Posted by Crewless View Post
    WALMART $29.97
    But is it rated for use with wet clutches?
    2014 Copper RTS
    Dec 2020
    Hartwell, Ga
    If this is it, then no. https://www.mobil.co.in/en-in/our-pr...l-1-fs-x2-5w40
    I use this myself, https://www.mobil.co.in/en-in/our-pr...bil1-racing-4t
    I cant for the life of me figure out why someone who pays this much for a machine then tries to save money on unapproved oil.
