Results 1 to 6 of 6
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Default Can an F3S use the same Rear 15" Rim on the 2015-21 F3S?
    Can spyder f3s use the same rear rim on the 2015-2021 f3s ?
    Last edited by Peter Aawen; 01-22-2023 at 04:14 PM. Reason: Expanded title to briefly ask the question??
    richie spyder
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    Yes. The part number is 705501992 and is used on many years and many models.
    Go to this link and hit “where used" on the right.
    https://www.canampartshouse.com/oemp...arch=705501992
    2015 F3S SE6
    Dec 2013
    Quote Originally Posted by Tourer View Post
    "The part number is 705501992 and CAN BE used on ALL years and models." Fixed it for you Tourer, & ssmcclub.
    The 15" rims were always standard across the Spyder range, the only differences ever being colour/style & that the earlier rims came as a 2 part rim, since replaced by an identical form, fit, and function 1 part rim; so if you've found a rim that fits and works on one Spyder, it'll fit & can be used on ALL Spyder models & years!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Apr 2013
    massapequa ny 11758
    Ok thanks guys
    richie spyder
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Just do not forget, to put your own sprocket, on te wheel, or you'll be surprised, by the many faultcodes you're gonna get... The rim fits, but there are a 2 kinds of sprockets on the rear wheel, and they cannot be changed.
    the funniest thing about this particular signature is that by the time you realise it doesn't say anything it's to late to stop reading it........
    Spyder F3s 2019 All Black ( Named it: Brutus)
    Carbon Items added, just for looks
    Upgraded Shocks Trac-Tive, Rear hi/lo and rebound adjustable, with Hydraulic Pre-Load adjuster
    fronts hi/lo and rebound adjustable, custom made by the Trac-Tive Guru's
    Swaybar (Ron's)
    Tyres Front Michelin Cross Climate+ 175/60-15
    Rear, for 2022 still a Kenda, next Yokohama Advan Fleva 205/55R15
    Exhaust Bone stock, with a RLS Cat- Delete
    Custom ECU-Mapping, rewritten/adapted to my Ridingstyle
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Piratezz View Post
    Ah! You beat me to it! And I was going to sound so smart and wise.... Well, you win some and you lose some. Great Advise!
