Results 1 to 6 of 6
    May 2020
    Virginia
    Default What's best for Cleaning leaves out of the engine compartment?
    I have a 2020 Spyder RT. I have found that it is a vacuum. Is it possible to raise it up on ramps and remove the skid plate to wash or blow out the leaves I have fond in there? Please be kind.
    Last edited by Peter Aawen; 01-12-2023 at 01:31 PM. Reason: Expanded title to briefly ask the question
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Yes, there are two panels on the underside that are fairly easy to remove. Each one has a torx screw and 3 plastic push pins. The plastic pins can be a challenge, especially going back in. You can get to both of these using car ramps. Either then just pull debris out by hand, or use a shop vac.
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Feb 2017
    Although this isn't a direct reply to your question, you might want to look into Kotts grills. Lamonster sells them and we've found they do a good job at keeping rubbish from entering the intake openings.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Feb 2020
    illinois
    Or, trade for F3L. One of the reasons that I did. RTL was was like a road vacuum on multi day trips. Loves grasshoppers in the Midwest.
    Feb 2017
    Quote Originally Posted by baxter View Post
    A road vacuum! Love it.
    May 2020
    Virginia
    Thanks for the info
