Results 1 to 12 of 12
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Default What's the best pressure for Quatrac front tires on 2022 F3-L?
    Just installed new Vredestein Quac 175/55 R15 front tires and
    General Altimax Rt43 225/60 R15 rear.
    Question is what, would be the best air pressure to use?
    I am an aggressive driver.
    Thanks for the help
    Last edited by Peter Aawen; 12-21-2022 at 06:06 PM. Reason: Expanded title to briefly ask the question
    2022 F3 Limited , Monolith Black / Dark
    Jun 2016
    indpls in
    20 lbs
    Mar 2013
    Marion, Arkansas
    but some say 18 lbs.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Apr 2014
    full time RV'er on the road. Well we were. Now, 6 months in ThreeRivers Mi and 6 months in Apache
    I had the Vredesteins on my ST. I weigh 155 lbs. I put almost 30K miles on them before I sold the bike. At least 10K of that was in the Applachians and they looked like the had another 20K left when run at a constant 18 lbs.
    I have them on my RT, for NORMAL riding 15 psi is fine ..... for aggressive riding I use 17 psi ..... with any tire the higher the PSI there will be a commensurate loss in COMFORT .... any Auto tire used on a Spyder will begin to lose it's TRACTION if the PSI's are above 22 PSI, the higher the PSI the more loss in traction. I've said this dozens of times, the TIRES are an integral part of the Suspension. ..... Mike
    Very Active Member CloverHillCrawler's Avatar
    Mar 2021
    Maryland
    I ride in a more "spirited" fashion and 18 all the way around gets better gas mileage, 16 gets better grip.
    2020 F3 SE6
    Safety and Lighting: LED Headlight upgrade, IPS LED Fog lights, Show Chrome LED Fender Signals, LED Signature Light, Tric LED Afterburnerz, MotoHorn 2.0
    Suspension: Wilbers Front and Rear Shocks, BajaRon Sway Bar, Vredestein Quatrac Front and Rear Tires
    Comfort: Blue Ridge Windshield, Corbin Dual Touring Saddle, Ultimate Floorboards, OEM Passenger Backrest with Rear Shelf, OEM Passenger Floorboards Modified with High Risers from Pierre
    Tackform Center Mount Phone Holder w/ rapid charging USB-C.
    2020 F3 , Black
    May 2017
    Mesa, Arid-Zone-A
    Three tires, 18,18,18.....
    Semper Fi
    Jan 2021
    northeast pa.
    Quote Originally Posted by DriftersWay View Post
    Thanks for the help
    may i ask why new tires already on a new machine, and any rubbing with the larger front tires than stock..thanks
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Quote Originally Posted by fredgal View Post
    Well I'm guessing He wanted two of the best tires available ..... And those 175/55-15's will fit without issues, but they are about as large that will ...... Mike
    Sep 2019
    Central Texas
    Didn't notice if you stated what model you have, RT or F3. I ride a 2019 F3L with the Vredstein fron tires and Kenda rear. I'm an agreesive rider myself. 18 lbs for the front and 28 in rear.
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    Easy way to tell if you are at the correct pressure is to start with the recommendations here, ride like you normally do for at least 30 minutes then measure the pressure. If you see about 4 psi rise you are golden. If more than 4 psi rise you need to add air. If you only see a 2 psi rise drop the cold pressure by a pound or so. Rinse and repeat.
    The Journey IS the Destination
    2016 F3-T , Intense Red Pearl
    Active Member Reacher68's Avatar
    Jul 2018
    Grand Prairie, TX
    I've been running 18 in mine since I installed them a couple years ago. They still look new.
    2016 F3-T
    Places I've ridden.
