What's the Best horn upgrade for 2020+ RT?
I want to upgrade the wimpy horn on our 2022 RTL, I cant believe they come with such a wimpy horn. but anyway, what is the best horn kits out there for the 2020 & up model RT ? Im not looking for an air horn style, Just a regular horn.
https://smile.amazon.com/Wolo-419-Ba...s%2C335&sr=8-3
WOLO Bad Boy 419 is what I have on my 2017 RTS. Pretty darn loud @ 150db. Easy install for me, as I could easily get to the stock horn. Comes with the necessary relay and very good instructions. You will need a 20 amp inline fuse, you can get one at any auto parts store. I also needed an "L" bracket, which I happened to have. I wired it directly to the battery, I had the necessary wires (red & black, 16 gauge) and connectors etc. also available at an auto parts store, and fishing the wires from the horn to the battery was a little time consuming, but when all was said and done, still only took about an hour.
There is also this one @ 150db.
https://smile.amazon.com/Wolo-619-Bi...s%2C335&sr=8-5
Best of luck!
I installed these dual horns from Sling Mods on my wife's 2021 Sea to Sky. Installation is a bit tricky but worth the effort. https://www.slingmods.com/canam-spyd...s?search=horns
2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
We installed https://motohorn.com/product/motohorn/ and love it.
We like a good, loud horn that get attention and this does the trick. It looks big, but blends in nicely with the bike.
https://motohorn.com/gallery/can-am-spyder/
2013 F6B
2016 F3 Ltd
I’ve got the Wolo Bad Boy on my ‘21 RT. It’s plenty loud enough, fits in the same spot as the stock horn (comes with a custom bracket but it is tight to get at the mounting nuts), and most important of all, it simply uses the existing wiring and spade connectors as it is not an air horn per se. I’m very happy with it.
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
Peter Pan has struck again!
Originally Posted by Arion
I have the same horns for both the wife's Ryker and my Spyder. Installation on my Sypder was a bit harder but well worth it. They are definitely loud.
2021 RT Base - Petrol Blue
I have these saved on my list. What % louder do you think these are over the stock one ?
It's been so long since I installed the horns but if I was to estimate from memory, the horns I installed from slingmods have to be at least 2.5 to 3 times louder. They are loud. In fact, a while back someone cut my wife off to get off the highway. I pulled up beside him while he was on the off-ramp and blasted my horn. It scared the bajesus out of him.
That’s why I don’t want one that is too loud, and am more than happy with the Wolo QuickDraw. Knowing my luck the dual horns would cause the other driver to jump……right into my lane that I am occupying
HeliBars Handlebars
Kenda Kanine rear.
2022 RT Sea To Sky
Have someone with a 2001-2010 GoldWing blow their horn for you. You can find plenty on ebay.
1976 RD400c
