Originally Posted by rjinaz86323
Does anyone know what the bracket bolts to. I am wondering if it would be secure enough to attach a bracket to the base to be used to hold a GPS. I would like to get my GPS up higher without mounting it on the bars.
Thx
It's attached to the windshield Motor .... The windshield and bracket both shake a little, so whatever is attached that will shake also ..... good luck .... Mike
I have a 2019 RTL and have my XT high mounted at the edge of the dash using Ram Mounts and one of these brackets. However, I don't know if the cross bracket will work on 20 and up rigs.
https://spyderstore.com/index.php?ro...&product_id=51
Knowledge is the accumulation and remembering data.
Wisdom is the effective application of it.
[img]https://www.spyderlovers.com/forums/maps/map.png?
I mount mine on a RAM mount, middle of handlebars. Very solid there, and can easily be adjusted out of the way of the instruments.
Andrew
Melbourne Australia
2016 F3L Spyder
Now, wash your hands
