Results 1 to 3 of 3
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Default Is 2022 F3-L rear tire removal the same as RT-L?
    I have a 2022 F3-L will the removal of the rear tire be the same as the RT-L.
    Thanks
    Last edited by Peter Aawen; 12-06-2022 at 05:34 PM. Reason: Expanded Title to briefly ask the question ;-)
    2022 F3 Limited , Monolith Black / Dark
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    The removal of the brake caliper, axle and tire is essentially the same procedure as the RT-L. On my 2018 F3-L, the mud flap removal is quite different than the RT. I remove the side boxes and the muffler to gain easier access to everything involved in changing out the rear tire.
    Sep 2013
    Houston
    Quote Originally Posted by DriftersWay View Post
    Thanks
    No need for fender or saddle bag removals. Remove the shock bolt and lower the swing arm. This also takes all tension off the belt making removal very easy. Axle, brakes etc are completly exposed for removal as well. Then the tire/ wheel comes right out. Don't forget to disconnect the ride height sensor before you lower the swing arm.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
