Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Jan 2019
    Hunter Valley NSW Australia
    Default What's the Best way to fix this tire?
    I am uncertain if should use a Rawhide Tyre Plug or Finelec to fix this, I am out of duct tape.
    2017 RTL
    2017 RTL , White
    Sep 2017
    INDIANA, USA
    Default Best Way? ?
    ....Who is the manufacture of the Tires?
    Need more pictures of the Tire.
    Did anything get damaged?
    Stay Healthy. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Sep 2018
    Australia
    Hydrogen Harry's tyre service??
    2017 F3S Daytona , Circuit Yellow Metalic
    Dec 2013
    Quote Originally Posted by askitee View Post
    Bugga! Are you OK? No-one got hurt/anyone else involved??
    Dunno 'bout you, but I reckon that looks like it juuuust might be the end of that tire, even if you had more duct tape!?!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    have been contacted about your extended warranty
    Apr 2019
    Clinton, MS
    Thought you always carried a can of fixaflat with you. Would have saved the rollback cost.
    2019 RTL Phoenix Orange
    Sep 2016
    Chillicothe, Oh.
    Sorry, but the only option here is to put an inner tube in the tire.
    2015 RT , Black
    Feb 2020
    Minnesota,USA
    That tire could possibly see high speeds again, recycled into a box of rubber bullets!
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    No one has mentioned ride on.
    Me, I would get a couple new fronts and let the bugger go. Otherwise, you may have an uneven ride with the fix measures mentioned above.
    Dec 2020
    Hartwell, Ga
    Fill it with foam and never look back.
    Feb 2013
    Edinburg, TX
    Boil a box of Quaker Oats, add 1 & 1/3 lbs. of Grandma's Texas Honey, then stir together until well-mixed, and finally, blend in about six ounces of heated Elmer's New and Improved White Glue as a curing agent. Remove the valve-core to pump all the mixture into the tyre, then replace core tightly before refilling with the appropriate amount of air. However, beware that this might still leave a slow-leak condition, requiring you to re-check and adjust the pressure a bit more often... probably about every 13 seconds or so ought to do it. This short interval can be significantly improved by refilling the tyre with thick air* instead of thin air, but that's a little harder to find. Good Luck, mate!
    ( * This thick air is now used by our government for creating our money, since they created so much out of thin air that the supply ran out. Now they must rely on thick air for money creation, and thus hold quite a monopoly on the limited supply.)
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
    Quote Originally Posted by missouriboy View Post
    Off topic, but does the thick air money have move value than the thin air money?
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Great Joke!! :clap
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Jan 2019
    Quote Originally Posted by Knizar View Post
    LMAO with tears in my eyes
    2017 RTL
    2017 RTL , White
    Jan 2019
    I think I just wet myself reading this
    2017 RTL
    2017 RTL , White
    Jan 2019
    It started as the perfect ride with some favourite mates in perfect weather on mostly awesome roads and ended this way. No injuries.
    Clipped a rock, and everything felt ok, so I dropped back to 80km/h and after a while noticed the steering pulling to the left. Tyre leaking via a hole in the sidewall. Stopped for a look and as I was in the middle of nowhere decided to creep along between 10 and 20kms/h till I could get reception to call roadside assistance - next minute tyre disintegrated and grabbed a handful of the left front guard locking the wheel. As luck was still on my side I now had phone reception to call roadside assistance. The mates did come back twice to see what happened and I suggested they keep going until I get to town. When the tilt tray truck came, my mates were back and full of compassion - not - eager to get photos for posting on our FB group, contacting other mates so that they too could share in the moment.....
    The thing I am most worried about is how long it will take to get new bits.
    Thankful for the Roadside Assistance who came and picked up the bike and ferried it home the next day - about 250kms
    As an FYI - originally the Roadside Assist provider was only taking the bike to the next town - "Sorry but a flat tyre doesn't qualify for it to be transported to your home town". They did ask that I try to get a replacement tyre and then they'd help further with ferrying me to the tyre service that had one. I explained they are a very rare size.
    The Tilt tray driver owned a local tyre service, had never seen a tyre that size and already knew getting one would be diffcult. I rang all the major tyre chains and the replies ranged from "a what size - do they even make a tyre that size?" to "no way buddy and the computer isn't saying where I can get it from, can you wait a couple of days?" This played in my favour as the Roadside Service agreed they needed to take me and the bike home.
    2017 RTL
    2017 RTL , White
    Oct 2021
    Wichita, KS
    Yes, but what about the fender.......?
    Peter Pan has struck again!
    Jan 2019
    Quote Originally Posted by FrogmanDave View Post
    Yes up for one of them too. as well as the wiring harness for the lights etc
    2017 RTL
    2017 RTL , White
    Feb 2012
    Spring City,Utah
    They are a standard size and can be found anywhere,no big deal there.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Might not have happened if you'd remembered to switch out the summer air for cold winter air. Or better yet, paid extra for nitrogen!
    2020 RT Limited Deep Marsala Chrome
    2020 RT Limited , Marsala Red
    Feb 2013
    Edinburg, TX
    Switch out the summer air?? Right here on the cusp of summer, beginning about December 21st?
    Nov 2012
    Pueblo Colorado
    Like Askitee we were a ways from nearest services when I hit a rock washed onto the road during a downpour in the Arizona mountains west of Show Low. https://www.spyderlovers.com/forums/...90#post1397990 We were lucky enough to get a flat tow and found the Nanking Tires at the Discount Tire back at Show Low. Thankfully no associated other damage and after another night stay could proceed to Tucson. Another memorable trip on the Spyders.
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Jan 2019
    Quote Originally Posted by Jetfixer View Post
    Might not have happened if you'd remembered to switch out the summer air for cold winter air. Or better yet, I paid extra for nitrogen!
    Jetfixer, I was hoping no one would realise I had missed that - I keep it in a bowl in the garage and just thought "nah won't need it, I'll get the flat tyre next trip"!!!
    2017 RTL
    2017 RTL , White
    Aug 2007
    Greeneville, TN
    I don't see the problem... I'd run it just the way it is. At the right speed, centrifugal force will take care of the rest!
    Apr 2020
    tucson az
    It's like winter air and summer air
    2011 rt , pearl white
