Results 1 to 21 of 21
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Default Found a Push button garage door opener!
    Found a push button garage door opener at www.kustomcycleparts.com
    Easy programming…they have a YouTube video to demonstrate….I’m putting it in the blank spot on the switch panel of 2013 RT.
    Kelly at kustomcycle is very helpful and quick communicator…..the business card that came with my unit indicates use promo code THANKYOU on next order and save 10%.
    Kelly said he would be happy to work with spider owners if they needed something particular for their installs.
    Mar 2011
    Pence, wi.
    What is the part number? A quick picture of it would be helpful. Thanx
    Last edited by Peter Aawen; 01-26-2023 at 06:15 AM. Reason: added missing e's & ' 's ;-)
    2022 Spyder RTL- Chrome , Larger brake pedal Deep Marsala Red
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Tatonka View Post
    Did you by any chance ask about water proofness? It looks like there are several options, black or chrome. Thanks
    Jan 2018
    North Carolina
    There are several options that are based on the type of door opener you have. I first ordered one through Amazon and they sent me one that was not compatible with my opener. I went directly to Kustomcycles
    And they fixed me up with the correct transmitter. The small button goes basically anywhere you want it. The transmitter goes inside the body panels where it will stay dry in my case I inserted through the speaker cover opening. Check out the video on YouTube.
    Jan 2018
    North Carolina
    This is the unit…the push button requires drilling a 15/32 hole
    Mar 2011
    Pence, wi.
    Thanx for the pic!!
    Jan 2018
    North Carolina
    Default Opener installed
    Installation fairly straightforward… It would help to have the hands of a child to reach inside the machine however. Always some issue arises but all is well and functional.
    My solution was cost free .... I have an RT and just keep one of the openers in the glove box ..... JMHO ..... Mike
    Mar 2015
    Fritch, Tx
    I do something similar to BLUENIGHT911. Like most openers, mine came with two remote units. I keep one in my car and one in the inner pocket of my riding jacket. Our cars live under an open carport all of the time except when I take them up to the shop 80 yards away for maintenance issues & other duties. I don't put the spare opener in my wife's car because of the higher priority of needing it for use on multiple bikes, the Spyder and frequent openings with my car to carry out garbage and pick up my bicycle for rides two or three times a week. On the rare occasions when I need to work on her car, I simply use the keypad on the door jamb at the shop. Problem solved for free covering use of six motorcycles and one Spyder.
    Those who say " I can't" will always be right.
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    Almost the same solution for me, except I added velcro, so it sticks to the lid. I pop the lid open and hit the button.
    I like the install of the unit though.
    2022 Sea to Sky
    Feb 2022
    New Zealand
    I get by with these. 1 for the stand alone shop and 1 for the garage door attached to the house.
    I put them in my jacket pocket or glove box depending on my ride for the day.
    Yes I do have to come to a stop and push the button I guess but im happy enough with that.
    There are many suppliers for the remotes locally here in NZ so additional ones are no problem. They are not hard to program once you read the instructions . 1 set in each car, 1 for the bike of the day and a spare set for a rainy day works for me.
    Harrington, Australia
    Quote Originally Posted by Jesster72 View Post
    Ahhhhhhhh. Great minds think alike, Jesster
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2021
    OR
    2021 Syder RT Limited
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    "Ditto on the glove box." Simplest of mounts, under the glove box lid. No muss, no fuss. 21 RTL
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    May 2021
    Daytona Beach FL
    My door opener came with one full sized 3 button opener and one small, intended for keychain, 3 button opener. I was going to get one of the fancy ones that fills in the blank button on a 2020RTL and realized I already had a solution.
    https://www.amazon.com/LiftMaster-89.../dp/B00LC5DO3C
    This is what is velcroed to the inside of the of the little glove box. Lets me open either door!
    2020 Spyder RTL Chalk/Black
    2020 RTL , Chalk / Black
    Quote Originally Posted by Valkrocket View Post
    Yeah, that’s what all us “smart” (or is it “cheap” ) riders are doing, Valk
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2021
    IL
    I resemble one of those descriptors.........
    2022 Sea to Sky
    Aug 2013
    Uxbridge, Ontario, Canada
    I have a 2021 RT Limited and have purchased a Show Chrome garage door opener switch and need advice on how to install - thanks!
    Mar 2021
    Maryland
    I did this with a $7 remote off of amazon, visor clip works perfectly with my Tack Form center mount post.
    2020 F3 SE6
    2020 F3 , Black
    Danbury Connecticut
    Time to bring this out again.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Nov 2013
    Central Texas
    I'm Lazy. I carry an opener in the glovebox. No taking panels off, no wiring, just pop open the cover and push the magic button. !!Bonus!! With one remote I can open EITHER or BOTH garage doors!! Ain't technology grand!
