Results 1 to 15 of 15
    Jul 2022
    Washington state
    Default Can I connect my phone, GPS, & still intercomm with Cardo Freedom 2X?
    I just got the Cardo Freedom 2X. I've read the manual and watched a 30 minute video from Cardo but...
    Can I connect my phone, GPS, and still use the intercom?
    Last edited by Peter Aawen; 11-24-2022 at 03:15 AM. Reason: Expanded Title to briefly ask the question ;-)
    Jan 2021
    Monroe, la
    Yes you can. I had a Cardo G9 a few years back and it could.
    2010 RT
    2015 Ural
    1980 & 1982 R65 BMW
    1975 R90/6 BMW
    1956 Triumph TR3A
    Aug 2013
    SF Bay Area
    Most Bluetooth headsets have 2 channels as well as a GPS channel. Dual sets come already paired for intercom.
    2021 F3 Ltd , Magna Red
    Oct 2021
    Wichita, KS
    Yes you can.
    Peter Pan has struck again!
    Linden, CA
    You can if you don't try and connect to your spyder, BRP Connect don't connect most of the time
    Oct 2021
    Wichita, KS
    Disagree. My phone and Cardo Edge connect to the Spyder every time I ride. Let the Bluetooth load and the phone is connected. Turn on your Cardo unit and it connects instantly. Every time, without fail. Samsung S22 Ultra with Cardo Edge.
    Harrington, Australia
    Quote Originally Posted by FrogmanDave View Post
    Thanks Dave, I’ll have to give it another go. It certainly didn’t connect easily (and stay connected) for me, but I haven’t tried for 12 months and there have been a couple of app updates since then.
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Frostbyte's Avatar
    Nov 2019
    Florida
    I run Pak Talk Bolds. The trick I found that works is to connect my phone to BRP connect, then to my Cardo on BT Channel 1. After that, I connected my Garmin to my Cardo on BT Channel 2. Intercom is still good. Then when I turn on my RT, it all connects automatically, though BRP Connect is still inherently glitchy at times and I have to reboot it. The instructions to connect on the Cardo channels are in the headset manual, but are kinda difficult to find and, if you are like me, take a few attempts to get right.
    One word of warning. DO NOT connect your GPS unit to your phone, or it will mess up the whole deal...Don't ask me how I know this.
    Knowledge is the accumulation and remembering data.
    Wisdom is the effective application of it.
    [img]https://www.spyderlovers.com/forums/maps/map.png?
    2019 RT Limited , 2" Pedal Extender W/Oversize Pedal Phoenix Orange
    Aug 2013
    SF Bay Area
    Any smartphone integration system (HD Connect, BMW TFT, Honda Goldwing) all express NOT PAIRING THE HEADSET TO THE PHONE! Causes Bluetooth confusion.
    Oct 2021
    Wichita, KS
    I absolutely agree. The bt connection that may be established between Cardo and phone must be deleted for everything to work properly. When I wear my helmet on my other bikes I pair my Cardo and use it for control. When I get back on the Spyder I have to delete the pair before turning the Cardo on. I believe this is why a bunch of guys on here are having problems.
    Dec 2022
    Florida
    Do you use the usb cable also?
    Dec 2022
    Florida
    Do you also use the usb cable?
    Oct 2021
    Wichita, KS
    Quote Originally Posted by mandytuning View Post
    Not generally. I don't do much touring so I really only use the system for music. I have used the cable (and therefore the bikes display) but I don't like my phone being taken over. It works either way for me though.
    No such confusion with the Garmin XT, Flamewinger. It is perfectly comfortable having you pair your phone and your headset to the XT to access your music, traffic, weather, directions etc, etc, etc, and then pair your phone direct to your headset to enable you to use Siri (or similar). It’s another of the reasons I am not yet using BRP Go. I use Siri a great deal to save taking my hands off the bars.
    HeliBars Handlebars
    Kenda Kanine rear.
    Linden, CA
    YES you can
