Results 1 to 25 of 47
    Nov 2022
    North Carolina
    Default Battery Tenders - should you use them or not?
    Yay or Nay? what do you say?
    Sep 2016
    Amarillo, Tx
    Use one. Battery still good on 2016 model and 20,000 miles
    Feb 2021
    Southern Illinois
    100 percent yes. Great investment.
    Steve
    2020 RT , Chalk White
    Aug 2008
    MA & NH
    Yes. (Site says yes is too short an answer so added this)
    Clinton, MS
    If you have a Costco nearby they have the Battery Tender 4 Amp charger/Maintainer on sale for $34. Larger than one of their maintainer only units but offers a lot more.
    2019 RTL Phoenix Orange
    Florida Swamp
    Just got a new one for the mower. It don't get started as much in the winter, and battery gets weak from just sitting there for a month.
    2019 F3-S , Black & Silver
    Sep 2016
    Chillicothe, Oh.
    I never used one for many years and never had a problem, but todays motorcycles are constantly drawing a current from the battery and if not ridden for a longer period such as a cold weather spell the battery will discharge to a point where it won't start the bike. Short answer, YAY.
    2015 RT , Black
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    100% yes
    Bossier LoUiSiAna
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Yes, without a doubt.
    Your Spyder draws current just sitting there. For a mere $30, you can buy a Battery Tender and hook it up during the winter to prevent a dead battery in the spring.
    I've used mine for my Yamaha Waverunner, Harley and Spyder RTL with excellent results.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Linden, CA
    Quote Originally Posted by cjr00 View Post
    In a word YES, but only if you want your battery to last longer
    Dec 2015
    Oakley Utah
    Are you asking about the brand or the category?
    2014 RTL Platinum
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    When not riding , It is plugged in . (even after a ride it still says the battery is not fully charged) SO YES!!
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
    Mar 2020
    Western New Mexico (Thoreau)
    Yes, have used one on all toys! ATVs, lawnmowers, motorcycles and Spyders!
    2021 Spyder RT-L - Asphalt Grey
    • Vredestein tires all around
    • Rolo Laser Alignment
    • Lamonster tire balancing rings/front
    • Lamonster Sway Bar
    • Lamonster belt tensioner
    • K and N air filter
    • Rear cowl - in place when you remove rear box
    I don't think the question is sufficiently covered by a simple Yay or Nay answer, cos it's juuust a tad more complex than that!
    If you're riding your Spyder every week or so, &/or always running it for at least 30 mins or so at better than 'just poking around town' speeds, then you really shouldn't need to use a battery tender or maintainer (and remember, those two things aren't necessarily the same thing either! ) and if you do, you may well be shortening the potential life of your battery, if not killing it! Plus, if you always use a tender when not riding, you could easily 'hide' a dead or dying battery until it's too late! If you are doing that thru 'less than ideal/appropriate tender use', then you'll most likely only find out that your battery is no longer up to keeping your Spyder running &/or start it when you are away from home!! So if by using a tender too much, you are actually misusing it instead, then Nay!
    But if you only ever do short/slow runs, so the tender is needed to top up the battery between rides; if you're leaving your Spyder sitting around for weeks or months at a time between longer/faster runs & your battery will be noticeably discharging between rides; or if you're storing or laying up your Spyder for a longer while, like over an extended holiday or winter/snow season; then sure, use a battery tender, or better yet, a tender/maintainer - they can be a great device to help keep your battery in good condition and in those circumstances, your question warrants a Yay answer!
    So instead of a straighforward Yay/Nay answer, it really should be a 'given appropriate use for your specific riding/charging needs/conditions, then a battery tender might be a useful tool to help you keep your Spyder & its battery in good operational condition'!
    Cheers
    Cheers
    .... this is the Best answer for many reasons ...... let me add " battery Tender " is a Brand name, anything labeled as a " BATTERY MAINTAINER " is what you need ..... Mike....PS I have the 1330 eng. w/larger Alternator so I only use it if the Spyder is going to sit for an extended period of time ...
    Nov 2022
    North Carolina
    the category...looks like it's overwhelmingly YAY!
    Aug 2019
    Stoughton, WI
    No brainer .. Use them year round on my bikes.
    2022 RT Sea To Sky
    INDIANA, USA
    Default Battery Maintainer
    Simple answer ....... YES.
    Long answer, be careful about what type of Battery charger/ maintainer you use. As some types are not your friend, they can actually do harm to your Battery.
    Ask me how I know. Been there and done the wrong things.
    ENJOY YOUR LIFE WITH A SPYDER
    Sep 2014
    USA
    Would 9 years on the same battery help you decide and always used a Battery Tender.
    Vermont
    Yes, use a battery maintainer.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Half Cover
    Show chrome Trunk Shock
    Durham,Maine
    If you are going to store your bike for a great length of time, yes, if you're using it between rides, I think it's a waste of time, ride it!!!
    2012 RTL , Pearl
    Active Member Grayfox's Avatar
    Nov 2012
    Advance n. c.
    All the time
    Active Member ferrasr's Avatar
    Nov 2021
    Alberta
    I use battery maintainer for the long winter storage months in Alberta. Put battery maintainer on once a month for about 2 days then take it off which helps my peace of mind in not leaving it on all the time and maybe having some electrical/battery issues. I also add fuel stabilizer, pump the tires up to the max air and even roll it forwards and backwards monthly to help avoid tire flat spots. Have been doing this with motorcycle storage for over 30 years, seem to work for me.
    2022 RT Limited Petrol Blue Metallic Dark
    Active Member Northofthesix's Avatar
    Sep 2019
    Leamington, Ontario, Canada
    Mine is on a maintainer whenever I am not riding... 2018 still on the factory battery with no issues so I am quite happy with how it does.
    You can't get there from here....
    Mods and Tweaks:
    Showcrome Trunk Rack
    Showcrome LED Trunk Light
    Garmin 390LM
    Spyderzone Floating Hiway Boards
    Spyderzone Mount Dash Bracket
    BajaRon Antisway Bar
    Showcrome full-size brake pedal
    Spyder-2-Go Driver Cup holder
    Ram X phone mount
    SpyderExtras 12 volt Docking Station
    BRP Driver Backrest
    Monster 4K Action Camera
    Spyderzone LED Fender Mount Spotlights
    CASA LED Headlights and Foglights
    2018 RT Limited , Ashphalt Metallic
