Results 1 to 8 of 8
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    Default Highway RPM - F3T vs F3L
    Just changed from a F3L to a F3T and was wondering how much difference in cruising (70 to 75)
    rpm I may find ??
    thanks johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Dec 2013
    IIRC, there were only a few (earlier) years where there'd be any difference - most US Spec Spyders these days all have the same set of drive cogs/sprockets for their belts, and I reckon it's only the differences in belt length between the F3's & RT's that mean there's any rev differences for a given road speed there too!
    Not that I can recall off the top of my head what any of them are right now - but you did ask how much difference in cruising revs you'd find.... and unless you've been riding one of the earlier F3's that did come out with a different rear sprocket, the answer to that question should be NONE!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Active Member MNBK's Avatar
    Mar 2017
    Circle Pines, MN
    I have a 2016 F3T and my wife has a 2017 F3L. My RPMs at highway speeds are about 500 more than hers. The difference is due to the different rear sprocket.
    Dave....
    2016 Red/Black F3T w/ Audio
    Bajha Ron Swaybar, BRP driving lights
    F4 Windshield, Ultimate Tallboy Seat
    BRP Passenger Backrest
    Custom Dynamics fender lights
    Tricled Rear Bag lights w/ Flashing Brake Modulator
    Wolo Horn, Lamonster's Bungee Buttons
    Spyderpops Bumper Skid
    May 2013
    Apex, N.C.
    It all depends on the year model of your F3L and your F3T. The 2016 F3L was the only year with the larger rear sprocket and will be about 500 rpm higher than a RT or later model F3L. The F3T had a large rear sprocket until either 2018 or 2019 (2018 I believe). That is the year they went with a smaller rear sprocket. Now the only ones that get the larger rear sprocket are the F3S.
    Jun 2018
    Tonawanda, NY
    So it appears that a 2016 F3T will run about 500 rpm higher than a 2017 F3L at the same given speed. Am I correct ??
    thanks johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    Mar 2017
    Circle Pines, MN
    Yes you are correct
    Dave....
    May 2013
    Apex, N.C.
    Quote Originally Posted by johnv50 View Post
    thanks johnv
    You are correct. But keep in mind that the higher RPM will not necessarily mean worse gas milage. I actually tend to get better gas milage. I have also noticed that on my 2 wheeler, I get better gas milage when keeping the engine in the optimum rpm range instead of having it in a higher gear and lugging the engine.
    Sep 2008
    TX
    At the end of the day and ride, I usually will need 0.2-0.3 gals more over a 5 - 6 gal fill in my T than the L; that's about 5% more gas for the same number of miles ridden.
    pauly1 - SpyderDeb's 'wrench'
    2018 F3-T & 2015 F3-S Road Warrior Foundation Tribute customs
    IBA #48220 SS1000 BB1500
    2015 F3-S , OEM na Basic Black with Custom Wrap
