Before I buy a 2nd phone… could I just use it for BRP Connect functions?
I have a handlebar mount for my phone because I monitor my blood sugar on the display (I’m a long term diabetic). This means I can’t use BRP Connect since it controls the display. I can still use my phone for phone calls and music via Bluetooth, but none of the BRP Connect features.
If I had a 2nd phone with no phone service, could I use it just for BRP Connect functions like GPS mapping and the like? I could connect it to my main phone via Bluetooth if needed.
Thoughts?
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
Sorry -How would you get GPS with no service? Maybe stand alone GPS or like others have & not connect what all functions do or do not cooperate.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
you can use google maps offline ( it's a PITA).
BRP connect is useless (IMO)
buy a gps YOU can afford.
Using Sygic does not require phone service, Bfromia. It works off satellite signal. Of course, you would not be able to get weather or traffic inputs which DO require phone service.
I actually tried this with an old iPhone I had, OverHill. It does work, but it is limited as I mentioned above (and there are a couple of other “gotchas”). I also find BRP Go unreliable. It is one of those apps that is “nearly” there, but not quite, so it can frustrate the crap out of you. If you have to buy a cheap phone to try it, I would advise against it. You would be better off looking at buying Sygic for your current phone and run your GPS function from there…..better screen, too.
Pete
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Put a blank SIM in the phone for your sugar monitor. Use another phone for everything else. Many don't like BRP Connect, so check it out before commiting.
"Love 'em all.... Let GOD sort 'em out!"
2021 RTL Dark Chalk Metallic with comfort seat
1978 GL1000 w/'75 engine show bike
1976 RD400c
Thoughts?
Get a GPS!
I really wanted to use BRP connect. I had a second phone and could semi permanently store it in the glove box. I just couldn't get it to work effectively, and I am a technology person!
Connection to the bike was terrible (I often had to take the phone out and re-establish it), Sygic (and other) maps were terrible on the BRB screen. I ended up with a Garmin Zumo XT and love it.
Reason: Many don't see post titles, just thread titles! So instead of putting a comment in the post title field, if you want everybody to see it, include it in the post text. ;-)
2021 Spyder RT-L in Deep Marsala Red/Black - BRP Comfort Seat, Adj Handlebar Riser, Running Board Lights, Driver Backrest, Passenger Armrests. Fobo TPMS, Grip Covers, UltraGard Full & Half Cover, Passenger & Driver Drink Holders, Wide-Vu Side Mirrors, Show Chrome Luggage Rack, SpyderExtras Aluminum Belt Tensioner, Show Chrome Accessory Fuse Block, SpyderExtras Adj Highway Pegs, Carbon Fibre Grills, Full Repair and Maintenance Manual, Kapplock Garmin Nuvo XT Lock & Ram Mount Lock, LidLox Handlebar Helmet Lock, Hopnel Dashboard Storage Pouch/Trunk Organizer/Side Cases, Garmin Nuvo XT GPS, Signal Dynamics Heads Up Voltage Monitor, M1 Motorsports F/R Dash Cam, inView Helmet-Mounted Brake and Turn Signal Light, Pedal Commander w/ Silicone Cover & RAM mount, Spyder Extras Driving Light Bar, Denali D3 Driving Lights, SpyderExtras Light Bar, TAC Designs Side Mirror Stabilizer Kit, Carbon Fibre Trim, Hi-Gain Short Antenna, Headlight Skins, Mirror Turn Signal Lights.
You could get a cheap phone and use a pay as you go plan.
YES you can as all smartphones since the iPhone 3G (2008) have cell, WiFi AND GPS antennas. So the “Offline” GPS apps (Sygic & Genius Maps) work without WiFi or Cell. The only need for cell service is to get traffic and streaming music. You can turn on the hotspot on the active cell phone and connect the none cell to it if you need traffic.
It really is amazing how so many don’t know what smartphones can do.
formerly pman2011
Yes, use the main phone as a WiFi hotspot and connect (also called tethering) the 2nd phone to it via WiFi. You will now have internet service on both phones. Check your cell phone Data Plan because some carriers have a bandwidth limit on tethering, if you exceed it they may charge you for the extra bandwidth usage.
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
Can you tether the 2nd phone to your main mobile while BRP Go has the 2nd phone’s function locked and under its sole control, YIRYDE ? I didn’t believe that was possible?
Pete
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
formerly pman2011
Pete
Pete,
You have me thinking about this differently now, I believe it's possible since you will tether the 2nd phone to the main phone via WiFi, then connect the 2nd phone to BRP Connect via Bluetooth.
I will have to try this when my new phone arrives.
Reason: know - now ;-)
[B]
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
If you do decide to use a 2nd phone, consider a rugged model off amazon. They come with much larger batteries and are considerably cheaper.
Can you still charge them through the glove box usb though, Istayner? It struggles with enough output to charge anything larger than a stock phone.
Pete
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
