Results 1 to 11 of 11
    Very Active Member ahh-cool's Avatar
    Jun 2014
    south florida
    Default 18 Spyder RT will not turn on
    18 Spyder RT will not turn on. I turned the key and the display turned on for a second. I tried to boost it and couldn't start it.
    Even boosting it with the battery still installed the display did not want to come on.
    I took the battery out and it reads 12.7 volts. I boosted the bike with a car and got it home.
    Tried to boost the bike with a battery boost and the dash does not light up.
    I'm thinking it's a relay.
    Any ideas
    Jun 2014
    south florida
    Could it be the key switch?
    Sep 2014
    USA
    Battery bad
    Jan 2021
    Descanso, CA
    Wink Replace the battery
    Original battery? If so you have two choices:
    1. Replace the battery (search for recommendations).
    2. Spend days/weeks fooling around with relays and then replace the battery.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Quote Originally Posted by ahh-cool View Post
    Any ideas
    If the spyder started with the car battery - I don't think the relay is an issue .... as others have said .... look to the battery as the problem ..... Mike
    Jun 2014
    south florida
    I now don't think it's the key switch because the flashers didn't work. I know I was able to jump the bike and it started and I drove it home. I was getting ready to purchase a battery and I was trying to jump start it with a battery box and a car jump but I had nothing, no lights on the dash. I had it towed, free towing and he said it's the battery. I told him to put in a battery and check it a few time throughout the next few days to make sure. He said they are having a hard time getting batteries.
    I read this post a few times and frankly I'm confused about what going on ..... Mike
    Sep 2017
    Durham,Maine
    If you have changed the battery and keep starting it to make sure it's starting without riding it and charging the battery with the bike by riding it, IT WILL KILL THE NEW BATTERY! If it's straightened out and starting ride the thing and forget you ever had a problem!! good luck
    2012 RTL , Pearl
    Jun 2014
    south florida
    The bike is in the shop for the battery and the sprocket service bulletin. I am working 12 hour shifts right now and I don't have another vehicle to find a battery. I'm in a small town of 200 people.
    Oct 2016
    Faribault, MN
    Not to mention you've recently had a near miss from IAN. Hope they've found the fix, will charge your new battery to full and get that new sprocket on in time for your riding.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jun 2014
    south florida
    Quote Originally Posted by DGoebel View Post
    I'm in Minnesota, right now working the Sugar Beet harvest. Should be leaving here in about 2 weeks
