Results 1 to 11 of 11
    May 2021
    Florida
    Spyder Lost my RH ACCESS COVER - anyone know where to get replacement?
    Hello, I Lost my RH ACCESS COVER (OEM 708400257),
    Does anyone know where I can get a used or less expensive one? The color is Steel Black. Can Am wants $214 (seems a little steep to me for such a small piece).
    Jeff
    Last edited by Peter Aawen; 10-10-2022 at 11:45 PM. Reason: Expanded Title to briefly ask the question ;-)
    2017 F3-T , Brake extension and "3rd peg" Matte Black
    Member Misslizzy's Avatar
    May 2020
    Windsor, Ontario, Canada
    On my ride home from the dealership with my new 2022 F3-T, my left side cover came flying off. I stopped and tried to look for it in the near by field, but no luck. I called the dealership and they replaced it for free… They are poorly designed and shouldn’t come off so easily.
    2022 F3T , Pearl White
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    Hi jmack. If you want to try to find one used, here is the years and models that use that part. This information will help when you speak with the motorcycle salvage yards.
    ASSEMBLIES WHERE 708400027 IS USED
    2015 SPYDER F3 SE6 - Body And Accessories Console
    2015 SPYDER F3 SM6 - Body And Accessories Console
    2015 SPYDER F3-S SE6 - Body And Accessories Console
    2015 SPYDER F3-S SM6 - Body And Accessories Console
    2016 F3 000E6G - Body And Accessories - Console
    2017 F3 000E6H - Body And Accessories - Console - Package S-Std
    2017 F3 000E6H - Body And Accessories - Console - Package T-Ltd
    2018 F3 LTD SE6 - Body And Accessories - Console
    2018 F3 S SM6 & SE6 - Console
    2018 F3 T SE6 - Console
    2019 F3 LTD SE6 - Body And Accessories Console
    2020 F3 LTD SE6 - Body And Accessories Console
    2021 F3 LIMITED - Chrome Edition - Steel Black Metallic, (Built After Sept. 2020) - Body - Console
    2021 F3 LIMITED - Dark Edition - Steel Black Metallic, (Built After Sept. 2020) - Body - Console - China
    2021 F3 LIMITED - Dark Edition - Steel Black Metallic, (Built After Sept. 2020) - Body - Console - North America
    2021 F3 LTD SE6, (Built Before Sept.2020) - Body And Accessories Console
    2022 F3 LIMITED - Chrome Edition - Steel Black Metallic - Body - Console
    2015 F3S SE6
    May 2021
    Florida
    Hello, Im so sorry for never thanking you all for your responses. I'm kinda new to this format and didn't know where to find these responses. THANKS all!
    Jul 2023
    Ohio
    Quote Originally Posted by Jmack View Post
    Jeff
    Leaders rpm in michigan. Right hand access cover in black under $20 for 2020 f3 base.
    Lamonster also has a video on his site explaining how to attach access panel correctly.
    2020 F3 base, cruise control, pedal commander
    Lamonster led headlights and fog lights
    Bikemaster heated grips
    F4 windshield,Shad side bags
    Quick detach rear rack,Baja Ron swaybar
    Feb 2022
    New Zealand
    I had a surf around and found this site.
    Not sure if its up and running, but it's there.
    https://www.yamahapart.com/cart
    Cover panels.
    The link works but...
    Last edited by Peter Aawen; 02-22-2024 at 04:42 PM. Reason: Removed the pic you couldn't delete... & the comment. ;-)
    2017 F3 Ltd
    Dec 2022
    Florida - Wimauma
    Good to know all this.
    Had mine all apart for over a week. Parts I ordered still not in and Daytona calls so I put it back together. Took a full day to assemble what I had apart. Ride today on the interstate and I spotted my right-side panel flipping up and down. Pulled off and fiddled. No luck.
    Wife got mad at me so I slowly went holding it down until getting off at an exit. Got off the bike and still struggled to get the darn thing to hold tight in the front. Crap design but finally it stuck. Over 100 miles on mine right now. The more I play with it the less I like it. Then also the far less do I like the supplier I chose for extras. LaMonster is NOT that suppler as they don't deal with what I wanted. Maybe that's why?
    Mar 2015
    Tacoma WA.
    Jeff
    I would check out any junk yards or possibly eBay. As to what Can Am charges for a new one, welcome to Spyder parts!
    2017 F3-S Daytona , Yellow and black
    Durham,Maine
    I would hope by now he found his parts!!
    2012 RTL , Pearl
    Active Member a99miata's Avatar
    NW Florida
    sounds like a business opportunity if you have a quality 3D printer......
    Don't get mad at me if you don't like my answer.....
    Nov 2023
    Washington
    Leaders RPM has this:
    https://leadersrpmshop.com/can-am-ne...nel-708400239/
    They do not specify the color, but I'm pretty sure it is gloss black. You should call them to make sure it is the color that you want.
Tags for this Thread
