Results 1 to 7 of 7
    May 2020
    Australia
    Default Is this Belt adjustment OK? Comments welcome.
    When I adjust the belt it wanders from 1 credit card gap to 2 depending on where the rear sprocket is when rotating it, riding it every thing is normal with no harshness. I have a belt tensioner, it has not always been like this. On previous adjustments, the gap stayed constant. Your comments on this are welcome.
    John
    Last edited by Peter Aawen; 10-07-2022 at 05:33 AM. Reason: Expanded Title to briefly ask the question ;-)
    Dec 2013
    Unless it's wandering so much that the belt is partially moving off the pulley or it's wearing abnormally, then it's most likely fine!
    These belts generally wander far more than most think, but most don't notice it at all because they think the initial adjustment means it'll never move from there - but they ALL do to some extent!
    Seriously, it's most unlikely that it's anything to worry about; which means it's not a biggie, just normal wandering, so you can......
    Ryde More, Worry Less!
    2013 RT Ltd Pearl White
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Patt View Post
    John
    I agree with Peter, not to worry about that minimal movement. But would be nice to know what bike we are talking about, such as "Year, Make, & Mileage", maybe set up a signature! Bill
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Active Member cravenfun's Avatar
    Oct 2021
    Old Forge, NY
    Red dust on the front sprocket?
    John
    "some suffer from insanity, I choose to enjoy it"
    '15 F3S SE6
    '01 FLHR
    Ski Doo 1200's
    Boats
    2015 F3S SE6 , Magnesium
    May 2020
    Australia
    Thanks for the reply’s all, it is a 2019 F3 Limited with 35000ks. The front sprocket's been checked by a dealer, now waiting for replacement. Will probably have to re adjust it after sprocket replacement, not much faith in the dealer where I bought it.
    ..... about belt movement ..... Someone did a nice video ( saw it on U-Tube ) that showed the belt moving constantly, while the spyder was being driven ..... Mike
    May 2020
    Australia
    Thanks Mike, will see if I can find it.
    Last edited by Peter Aawen; 10-10-2022 at 07:36 AM. Reason: ..ike,wi.. - ..ike, wi.. ;-)
