Results 1 to 9 of 9
    Member cphillipsea1's Avatar
    Jul 2016
    Campbellsville KY
    Default Cannot get to rear bulbs - what am I doing wrong?
    brake, tail, backup... I cannot get to them, doing something wrong?
    Can someone tell me how to open it up to get to the bulbs.
    Thanks
    Last edited by cphillipsea1; 09-29-2022 at 07:22 AM. Reason: Expanded Title to briefly ask the question after move fm DIY How To: Guides...;-)
    Apr 2019
    Clinton, MS
    It would help to know on what model.
    Jul 2016
    Campbellsville KY
    2014 year 1330 engine RTL
    A video would help (slow learner)
    Last edited by Peter Aawen; 09-29-2022 at 09:03 AM. Reason: Caps & wound - would ;-)
    Quote Originally Posted by cphillipsea1 View Post
    Whenever I have questions about how Spyderparts go together I will go the Fiche' ( from after-market parts) that shows how all the corresponding pieces fit together .... it has helped me in the past ..... good luck .... Mike
    Apr 2019
    Clinton, MS
    Not a video but instructions for installing lighting from Spyderpops site. One of the steps is removing the tail lights.
    https://spyderpops.com/brake-run-tur...odels-2010-19/
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Here is a video for installing Saddlebag LED's which requires the removal of the rear lights. Disregard the section to remove the saddlebag inner panel.
    https://www.youtube.com/watch?v=LyugJUNAnqc
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Sep 2012
    Stetson, Maine
    I just checked my parts list in the manual. I have a 2011 but the rear tail lights are the same. I first remove the trim below the rear release latches. Open both side bags and rear trunk. There are 2 screw have to be removed from both sides. Then 4 screws around the rear trunk latch. Be careful on removing the left and right side fingers of the panel. After that panel is removed you have access to the light assemblies and this where you can also adjust the side latches. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Jul 2010
    Las Vegas, NV
    What Safecracker said.
    Why? The tail and brake lights are LEDs. If you say what you are trying to do, we can get you there. Joe
    Joe Meyer
    Idaho
    Thanks
    Brake and tail are in the LED assembly. You don't get to those. The backup and turn are incandescent. You have to remove the rear panel, 8 screws, to get to them.
    2014 Copper RTS
