Results 1 to 13 of 13
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    Default Need More Room on F3 Driver’s Seat - any modifications out there?
    Wondering if anyone has modified the drivers seat on an F3. I need more room front to rear. The distance now is crushing the family jewels. If no one has done this, will be looking to purchase a used seat.
    With the low amount of miles I ride, an aftermarket seat isn’t worth the expense.
    Last edited by Peter Aawen; 09-24-2022 at 05:48 PM. Reason: Expanded Title to briefly ask the question ;-)
    2015 F3S SE6
    Oct 2015
    Lynden, WA
    I had my F3T seat modified by Seth Lamm. Moved me back and a bit up. Much better than OEM.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2013
    Maumelle, AR
    Have you moved your footpegs forward to the #4 or 5 position? That might give Big Jim and the Twins a little more breathing room.
    2020 RT Limited , Chalk
    Sep 2017
    Durham,Maine
    Quote Originally Posted by Tourer View Post
    I would think making the boy's happy would be worth the expense, if you know what I mean!!! I would ether head to a upholster, or a custom seat shop and have a talk!! Make the boys happy!! Good luck
    2012 RTL , Pearl
    Jun 2016
    Harrington, Australia
    I had exactly the same issue, Tourer. Unfortunately, it’s a trade off. You either live with the “crush’, get your stock seat modified (like Haze mentions above……I used Russell daylong), or buy a longer aftermarket seat……and surely you don’t want to live with the short and long term effects of the crush, regardless of how few miles you do
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2015
    Tacoma WA.
    Try putting an air cushion on the seat. worked for me on my F3.
    2017 F3-S Daytona , Yellow and black
    Active Member Smokes's Avatar
    Jan 2017
    Melbourne, Australia
    Maybe it's time for a diet...
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Now, wash your hands
    May 2013
    Apex, N.C.
    I have a corbin seat that needs a new cover. Not sure if it will give more room, but you can give it a try. It will also give you a chance to do a custom cover for it if you like. I am also in NC and if you would like, we can meet and you can give it a try. Even if it doesn't work, you have a great base to trim some before having it recovered. I will make you a great deal on it, as it is just taking up space. I haven't listed it for sale, as I don't want to deal with shipping such a large item. Let me know if you are interested.
    Jun 2016
    Quote Originally Posted by Smokes View Post
    I can only assume you are not tall, Smokes…..that will do it, regardless of weight …..
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jul 2022
    North Carolina
    Thanks blacklightning for the seat offer. Going to go with an air cushion and see how it feels.i
    2015 F3S SE6
    Jan 2017
    Pete
    Well, let's just say that if there were six positions for the brake pedal, I'd use #6.
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Jun 2016
    Wow……I only used position #5 on my F3-L, so you must be at least 6’9”, Andrew
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Linden, CA
    Hi Dave here with HELP !!! yours is an easy fix that will not cost you a zillion dollars to cure.
    I have been a custom seat builder for over 45 years I can show you how to not get your wallet raided.
    Give me a call 209-887-3283
    Dave
    motorcycledave.com
