Opinions on un-weighting front suspension during Winter storage?
Winter is fast approaching in the Midwest…… storage question…… any opinion on unweighting the front suspension while in storage over the winter?
Reason: Expanded Title to briefly ask the question ;-)
SpyderLovers Ambassador
Winter Storage
Not sure what you mean by this statement.
Have you done something like this in the past?
Are planning to store for more than a year?
Over to you/your thoughts. .....
ENJOY YOUR LIFE WITH A SPYDER
My Spyder ..... 'Little Blue-Boy'
For storing my Spyder over winter I use my Big Blue lift. I know it is an expensive option but I purchased it originally for my Gold Wing and it can be configured for a large variety of bikes, and is ideal for working on the Spyder as it is very safe. Also I read that certain parts of the USA suffer with "critter" attacks in storage. The Big Blue standing on only one leg should be very easy to "Critter" proof.
Alan.
I am wondering the same thing?
Peter Pan has struck again!
He is referring to ..... lifting the front of the Spyder so the wheels are not on the ground. .... This will remove any pressure of the Springs ...... JMHO .... Mike
That’s correct, help eliminate some spring sag.
I have never done that, however I did always put the front and rear tire on a 2 x 6 plank so that the rubber was off the concrete over the winter...supposedly helped to prevent rot of the rubber by keeping them off the concrete. I don’t do that anymore as now I’m only down maybe 2 months.
Tri-Axis Chrome Handlebars
Sena SM10 BT Dongle
Double USB Port/Volt meter
LaMonster Magic Mirrors
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
LaMonster Cat Delete
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
2014 RTS-SE6 - Cognac
I put my Spyder on auto wheel Dolly's. That way I can move it around the shop without having to start it.
Also makes it easy to "tuck it in a corner"
Gary
2017 RTL Asphalt Gray Metalic
1987 BMW K75s
Un-Weighting?
Just wanted to know if you are doing the front end unweighting? I'm not sure if any issues are going to be a problem either way. Just thinking about this, seems maybe another over thinking issue.
Your Spyder, so do what makes you feel good.
Stay Healthy. ....
i'll make sure and ride some extra miles for you guys that get snowed in or frozen in.
Stay Healthy. ....
Well the tires could get FLAT spots, over the winter or long extended periods of dormancy ..... I keep my Spyder in my heated basement, I also fill the auto ties to their MAX .... This has worked since 09..... Mike
I say, do whatever you think makes you sleep better at night.
I also say, your Spyder doesn't really weigh all that much and doing all that extra stuff is needless if it's only going to be stored a couple of months, so ....
SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
2016 Toyota Sienna SE - hers
2002 BMW 325i - his
1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
2018 Can-Am Spyder RT Limited - hers
2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
2011 Tao Tao 50 - whoevers bike is in the shop
2007 Reinell 186 FNS - the dog's
1995 Fleetwood Flair 27R - EVERYBODY'S !
Just a guess but wouldn't whacking a dirty big pothole at full noise do about 40 years spring collapse versus just sitting in the shed.
Originally Posted by Peacekeeper6
I say it's only going to be stored a couple of months, so ....
That’s certainly open for debate..
We don’t all live in a temperate climate......ARtraveler used to live in Alaska, I used to live on the Alaska Highway, and we both had a lot more down time than a couple of months....I used to be down for 6 months....EVERY YEAR!
Sena SM10 BT Dongle
BajaRon Swaybar
HALO Skid Plate
Shorty Antenna
Akrapovic Muffler
FOBO2 TPMS
Rear Trunk Rack
Bruce Erickson
Chilliwack, BC
Canada
I certainly wouldn't worry about it but if you are, then jack that sucker up. I certainly can't see it hurting anything.
Whether stored over winter, as up north, or ridden 12 months a year, as down south, I've not heard of spring collapse on these machines. What can happen is the tires may develop flat spots from the extended sitting. Most would not be permanent given a few months duration. When we lived "up north", I made cradles for the tires by modifying Northern Tool furniture dollies for mobility in my garage and getting the tires off the concrete. I normally run 25 psi in all three OEM Kenda tires but would increase for the winter to 35 psi. If it were me, and not having to move the Spyder during the winter, I'd place a wide enough board under each tire for full support of the tire contact patch and increase the tire pressure to 35 psi, regardless of tire brand and what your 'normal' tire pressure setting is.
pauly1 - SpyderDeb's 'wrench'
2018 F3-T & 2015 F3-S Road Warrior Foundation Tribute customs
IBA #48220 SS1000 BB1500
2015 F3-S , OEM na Basic Black with Custom Wrap
