Results 1 to 10 of 10
    May 2021
    WA
    Default Momentary over heating shown on gauge - any ideas?
    This Happened two times to my 2015 Spyder RTL. The temp gage pegs to the top, with the fans running. seconds later it drops back to normal. Any ideas? The first sign of any trouble with the bike in 40,000 miles.
    Quote Originally Posted by Robbob1953 View Post
    I had this occur ( a few times ) ..... it was because the COOLANT was 16 oz. LOW ..... I topped off ( with DexCool ) and it stopped occurring. I then took a trip and the AMBIENT Temp gauge went to 125 F in bumper to bumper traffic. However my RT didn't overheat .... Checking the fluid level ACCURATELY is almost impossible. I over-filled it and the spyder expelled the excess, and I haven't had any issues since . ..... good luck .... Mike
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    There is a bleeder screw on the front of the engine block on the right side, below and forward of the water pump. It is very hard to see but I attach a clear hose to it, run it to a "catch can", open it, run the engine while adding remaining initial-fill coolant at the res and when there is no more air exiting the bleeder close it off, fill the res to the cold line, then bring to temp and wait for the fans to cycle, then shut it down and let cool. Top off the res as needed and you're done. Never ended up low or overfilled this way....
    Chuck
    May 2021
    WA
    Thanks, Friends I will look into it further.
    Active Member spyderider1's Avatar
    Jan 2018
    Wisconsin
    Yup, happened to me this past summer, low on coolant. Funny thing was, it would only peg the gauge when I turned left so go figure. Topped it off and all is good!
    LORD GRANT ME THE SENILITY TO FORGET THE PEOPLE I NEVER LIKED,
    THE GOOD FORTUNE TO RUN INTO THE ONES I DO LIKE,
    AND THE EYE SIGHT TO TELL THE DIFFERENCE.
    2016 Spyder RTS
    Sep 2017
    INDIANA, USA
    Default Coolant Level
    ... Well, the coolant level on your Spyder can be a interesting issue. I had the same problem that was posted.
    The temperature gauge and fans did the same game. The problem was low coolant, do to a cracked over flow tank.
    The Dealer made the repairs. I am happy but my wallet was empty. ......
    The service manager said that tanks have cracked on a handful of 2014 to 2019 Spyders.
    Not sure why. ......
    ENJOY YOUR LIFE WITH A SPYDER
    Sep 2014
    USA
    Could be a sticky thermostat.
    Bossier LoUiSiAna
    Not just coolant level but age flush refresh every 2yr. Not just dilute with water.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    2018 Spyder F3 Ltd
    2018 F3 Ltd. , Black/Dark
    Quote Originally Posted by hypurone View Post
    Many many folks here have reported that the drain valve BROKE off when they tried to open it .. So it's been recommended to NEVER touch that valve ..... Mike ........
