Results 1 to 19 of 19
    Active Member Wrongway's Avatar
    Jul 2017
    Tillsonburg Ontario Canada
    Default Just a thought regarding searching on the forum
    I’m posting this realizing that I may get flamed because I’m fairly new…………..However……
    Today I was doing searches on fuel range for my 2011 RT.
    It would really be of assistance on all searches if everyone was kind enough to put their year and model of Spyder or Ryker in their signature.
    That way it would always be there which would assist is searches.
    Just a thought.
    Greg
    Greg
    2015 RT Limited (White)
    Oct 2021
    Wichita, KS
    It is stickied at the top of this sub forum https://www.spyderlovers.com/forums/...ssed-On-To-All
    Not that all people read it, or do it, but it is there.
    Last edited by Peter Aawen; 09-16-2022 at 06:06 PM. Reason: Made sure link worked properly! ;-)
    Peter Pan has struck again!
    Faribault, MN
    Yea, we've only been asking that since before you got your Spyder.... Apparently communicating the full thought is a lost art. Many poster's assume we magically know what bike, model, and year they're asking about. But I'm sure you've been told, fill it up, drive it until you're coasting or you just had to put fuel in. A 260lb rider is gonna get way different mileage than a 160lb rider. I took a REDA Spare Gass can on my '13RTL and rode a quiet highway in MN until my '13 sputtered, poured in the spare and headed back home stopping at the first station. 150 miles one tank to coasting, I think over the years, using a gas can top off, the best I ever got was in the 160's and it took a full 6+gal tank to fill up.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Oct 2021
    Wichita, KS
    Not sure about the relevancy of this post to this thread.
    Sep 2012
    Stetson, Maine
    It will depend on your speed. Between 45 to 60 mph you should get 160 to 180, but do not pass a gas station at 120 miles to be on the safe side. Between 65 and higher I would be filling up around 100 to 120 miles. My experience, yours may very. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Harrington, Australia
    Quote Originally Posted by FrogmanDave View Post
    Hahaha…..I believe David and Bruce may have had a few too many scotches before posting and opened the wrong thread, Dave
    (Unless a post has been deleted, of course)
    HeliBars Handlebars
    Kenda Kanine rear.
    No posts deleted..... well, not yet, anyway!! But I think posts #3 & #5 are simply trying to answer the 'fuel range' bit that Wrongway mentioned in passing instead of discussing the thread topic, which is 'Searching on the Forum' and the suggestion that it would be nice & help if all users put the Year & Model of their Spyder/Ryker in their sig line - as asked in the sticky Frogman Dave linked in post #2
    No biggie really tho, it's not such a big 'off topic' thing that we can't get over it, there's worse elsewhere & we'll just leave that bit alone & try to get back on topic; except I gotta to point out that regardless of their year/model, Spyder/Ryker owners should NEVER run their EFI engined machines 'til they're spluttering/out of gas, cos that WILL damage the EFI system & eventually cause issues - and there's heaps of discussion about the why's & wherefores on that particular subject elsewhere, if you search.... So now we'll head back onto the real topic....
    Wrongway, you are right, it would be nice & it'd help a lot; but apart from the Sticky that already exists (& many either just ignore or never even bother to read! ) there's no way we can really force members to do that thru the software, cos any modifications to the platform to do that will only make it more difficult & expensive to maintain & can also cause significant problems elsewhere.... . So we're left with reminding poster's politely that we often need that info to properly answer their questions & maybe occasionally pointing out that the reason we have Sticky's at all is cos they hold info/advice that's really worth reading & sometimes even acting on!
    Btw, anyone reading, have you seen this sticky??
    If you haven't already, it really helps readers if you do include that info!! . And if you have problems getting the info into your Sig Line, just PM me or any other Moderator & ask for help.
    Jul 2017
    I’ve read the sticky lol.
    And here I thought I had thought of a NEW IDEA……………NOT.
    DGoebel and safecracker…….thanks for the fuel range info.
    Greg
    Quote Originally Posted by Wrongway View Post
    Just a thought.
    Greg
    Your 2011 RT with the 998 engine will average 30-35 mpg or so. Your refuel light will come on at about 150. I once went 185 but was sucking fumes at that point. Most of the time, I would fill about 135 miles or so...just to be safe. Time to get off and stretch anyway. The newer 1330's (three cylinder) get about 40 mpg. Most get 200 miles before needing to refuel.
    WARNING, WARNING, WARNING.....YOUR MILEAGE MAY VARY. THE FEISTIER YOU DRIVE, THE LOWER THE MPG. I have owned seven Spyders, Four 998's and three 1330's. The mileage quoted above was pretty close on all the spyders.
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    When I search the forum I use duckduckgo with the following command: site:spyderlovers.com term1 term2 ... termn
    You can use all the normal operators like quotes(""), +, etc.
    Try this search on Google or duckduckgo or whatever search engine you like:
    site:spyderlovers.com +2020 "petrol blue"
    Much better results than the OR search the forum uses.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Jul 2017
    Quote Originally Posted by ButterSmooth View Post
    I actually have resorted to google as you describe because searching the forum is often so frustrating. I guess my point is………why have to do that with such a great forum of information at our disposal.
    I appreciate you answer though.
    Greg
    Jul 2017
    Thanks very much for your input. I’m currently at 149 miles on the tank and have 2 bars remaining with no low fuel light yet. I’m sure it’s close though.
    Greg
    One other tidbit. Automatic shut off does NOT equal a full tank of gas. Many find that an additional gallon can be put in the tank. After auto shutoff, pull the nozzel up to the ring. Slowly put in more gas until it fills to the ring. Stop, let it drain down and repeat. You will not overflow the tank, and will get approx another gallon this way. Now it is full for real. If you start calculating mpg, you need to fill the same way each time, otherwise, you do not have apples and apples.
    Jul 2017
    Hit reserve today at 167 miles. Rode an additional 15 miles and filled up as described above. I can’t remember now how much gas it took because I worked it our right after the fill up. Anyway, I know it was 35 mpg so I was pleased.
    Greg
    Sep 2020
    Central Oregon
    ARtraveler: "7 Spyders, 12 years, 175,500 miles" -- WOW just WOW!!!
    Spyder Tryke Pylot
    Dec 2015
    Oakley Utah
    Just a thought.
    Greg
    Yes, that would be nice. Also, using a proper description in the heading. But, it's not going to happen, unfortunately.
    2014 RTL Platinum
    Concerning the GAS bars you see .... The upper bars will move slower ( down ) than the lower bars do. Not very accurate, and not in a good way ....;. Mike
    ..... and I check this EVERY time I fill-up .... the only variance I get is because off the shape of the Nozzle assembly .... Mine is always between 1.3 & 1.4 gallons. ... I stop filling when the gas level is at the LIP edge ...... good luck .... Mike
    I see a reasonably good correlation between bars and mileage by figuring in two invisible bars at the top and one at the bottom. That generally equates to about 15 miles per bar. That means I've gone about 45 miles when the top bar disappears, and have about 15 or so miles left when the bottom bar disappears. I was carrying a generator on the passenger seat one time when the gauge was down to the last bar. It would have been too much hassle to take the generator off to fill up so I kept going. When I delivered the generator I had ridden a few miles with no bars showing. After I took the generator off I opened the gas tank and used a stick to measure how much gas was in the tank. There was about 2" left which gave me plenty enough to get to Costco several miles away.
